Results 1 to 7 of 7
Thread: 325i NEED HELP with ccv system I think
    Apr 2020
    Wisconsin
    2002 325i
    I am currently trying to figure out why my car isbn running, first things first I live in cold weather and was driving it and all of a sudden a lot of smoke blew out the back and oil lite came on.
    Was going to do compression test so I removed the spark plugs and I hydro locked my cylinders with oil. Cleared out cylinders and did a compression test and cylinders ranged from 190-210.
    drained the coolant and no oil in it, and the remaining oil in the pan had no coolant in it. So I bypassed the ccv system with oil catch can replaced all the spark plugs, new oil, new coolant, new coil packs, new oil filter and the thing still ran like garbage. So I drained the fluids again and again there was no oil in coolant and coolant in oil.
    Can someone please help me, I can't figure this out and I don't wanna throw more money into the wrong thing.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Depending on the speed you were traveling at when the CCV failed and you hydrolocked your engine, you may have a bent rod. If you were lucky and it happened at idle, I would just suspect that the motor is flooded, or you have a vacuum leak. It will take some time to get all that oil burned off, so if it just ran for 5 minutes, that's not long enough.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Apr 2020
    Wisconsin
    2002 325i
    Would I not hear rod knock then?
    dworthy's Avatar
    Nov 2010
    "Runs like Garbage" can mean a lot of things to a mechanic......
    A rod knock comes from two thing typically:
    1) Bearings
    2) Wrist pin
    Darin
    Current:
    Past:
    M-Flight Member
    Apr 2020
    Wisconsin
    2002 325i
    Well I replaced the MAF and the thing runs like a dream again.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I suggest you replace the CCV system.
    Jan 2012
    Bethlehem, PA
    2004 BMW E46
    Quote Originally Posted by MarcoZandrini View Post
    I would suggest (IMHO) you DELETE the CCV all together and use the pilot mod that is quoted in many places that uses a PCV valve and completely removes the CCV system. I did this on both my e46's and I have never looked back. I just removed it completely, the CCV components, and its the best approach to this risky cold weather issue for the e46.
  1. need help with new system
    By schnitzed328 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-17-2003, 12:37 PM
  2. Really need help completing my system. What amps should I get?
    By D Unit in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-25-2003, 04:38 PM
  3. I need help with a system
    By djyoungz in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-28-2002, 10:14 PM
  4. Interested in buying E30 325i...need help!!!
    By Charles McGill in forum 1983 - 1991 (E30)
    Last Post: 09-22-2001, 11:10 PM
  5. Need help, Strange cooling system problem
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 06-02-2001, 04:00 AM
