Results 1 to 4 of 4
Thread: Oil in the Coolant, even after changing Oil Filter Housing Gaskets
    Apr 2020
    Houston, TX
    BMW 435I GC
    i have a 2015 435I GC. My car only has 35K miles and i changed the OFH gaskets in November. Yes, you could tell that they were bad. Unfortunately, two weeks ago i received a message that my coolant was low, so i open the hood and noticed that one of the hoses that connects the OFH and the thermostat was busted. so i proceeded to replace the hose, but when i drained the coolant i noticed oil in the coolant again. so i decided to replace again the OFH gaskets thinking that i did something wrong last time. i drained and flushed again all the coolant, but after doing all the work i am still noticing oil in the coolant expansion tank.
    any ideas where else the oil could be leaking into the coolant lines?
    the car drives perfect no problem at all, no code, no engine light.
    Canada
    750 F01, 850i, LR3 HSE
    Unless you used a chemical cleaner you will never get all the oil residue out.
    This involves draining all the coolant, flushing the heater core and refilling with water and a chemical cleaner then running at idle with the heater on high for about 10 minutes.
    After this drain system flush heater core and fill with clean water and run again for about 10 minutes, this is to remove the cleaner.
    Empty system and fill with the correct ratio of coolant and water.
    Mark.
    Apr 2020
    Houston, TX
    BMW 435I GC
    Thanks. I will try it again.
    Aug 2016
    Kansas, USA
    2015 BMW 328xi
    Keep in mind, the oil filter housing is an Oil-Coolant heat exchanger module.
  1. Replies: 15
    Last Post: 01-13-2010, 01:13 AM
  2. Question after changing oil and oil filter
    By udha in forum 1983 - 1991 (E30)
    Last Post: 05-26-2005, 01:30 AM
  3. Performance gains after changing oil?
    By DrittesAuge in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-17-2003, 12:12 AM
  4. Noise after changing oil
    By Estoril ART in forum 1992 - 1999 M3 (E36)
    Last Post: 07-18-2003, 07:27 PM
  5. No start on M3 after changing oil
    By Adam_ArticM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-09-2003, 06:23 PM
