It initially starts fine but after 2 seconds it acts as if it is starved for fuel and stops. Sometimes with pumping accelerator can keep it partially running. No codes displayed. Replacefuei filter, intake cam position sensor. Checked fuel pressure and it is constant 55#,
a y ideas?
Welcome to the Forum!
What are you using to read the codes? Does it have the ability to view live data?
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
It is a Bosch mobile scan. Unfortunately it does not stay running long enough to see anything
So let's dive a bit deeper into this.
What work has been done recently if any at all?
Mileage, and going to assume it's the car in your "My Cars".
So how much electronic knowledge do you have? I am thinking you will be testing multiple sensor, and will need a multi-meter to do so here.
Darin
Current:
Past:
M-Flight Member
Nothing at all recently, in fact it sat for a good while. Before it sat far a while, I had two occasions while driving it exhibited the same symptoms but snapped back running without leaving me stranded.
i have a multimeter, and fairly good at troubleshooting as long as I have an understanding of how it works.
car has 145000 miles on it.
thank you for your help.
Okay, how long has the car been parked? Is this fuel older than 6 months? Did you put any fuel stablizer in prior to storage? You maybe also dealing with other problems other than electronic here.
Darin
Current:
Past:
M-Flight Member
