I just parted out a few cars, and have 2x S54's and an S65 available.
E46's under 100K mi have become very tough to find, and I usually can only buy one a year, two if I'm lucky. I was able to buy 2 sub 100K cars recently!
Engines came as pictured, and generally included all bolts on + harness. If you're doing a swap, I can work a package deal included ECU, FPR, Fuel Pump, etc etc
I have the following motors available:
1) S54 - Pulled from a very clean 06 M3, rear hit. Just over ~80K miles. Ran very well, and solid compression on this one. Motor is very clean, as was the whole car! - $sold
2) S54 - Pulled from an 04 M3, only ~70K miles. Pulled from a clean car that ran excellent. Includes Rogue Pulley Kit. Car was hit in shock tower and the engine harness has some damaged connectors- $4,950
3) S65 - Pulled from 09 M3, ~100k mi. Pulled from side hit car. Ran excellent, and solid compression. Complete with harness and acc. Airbox has a hairline crack. - $5,950
I also have an S54 with a hole in the oil pan. I did not run it. It DOES turn over. $SOLD, firm, takes its!
Local pick up is ideal, but I can wrap / pallet and deliver to freight hub for $200, freight at your expense.
PM me if interested
Thanks for viewing!!
#2 harness
Bump!
The s54 with the hole in the pan, how many miles were on it?
Sold all motors on this listing.
I am dropping an S54 with ~140K this weekend, pulled from an 05 ZCP M3. $4400 obo
PM me!
