For sale - front & rear, like-new (<500 street miles on full kit), no longer available, PFC BBK. Details below -
- Front: 4-piston billet Z45 calipers; V2 323x32mm rotors
- Rear: 2-piston billet Z29 calipers; V2 321x30mm rotors
- PFC Z-Rated pads on both F/R
- All original hardware, brackets, banjo bolts included
- PFC stainless steel brake lines included
- 'Z' decal on rear calipers easily removable
Full plug n’ play PFC BBK that will need nothing except installation. The whole kit has under 500 miles and nearly flawless.
These are of the very few kits that fit under the OE 17” Roadstars (w/ 12-15mm front spacer required - which you should run anyway!) and perform incredibly well.
I will not split the set and am not very negotiable; you’ll be hard pressed to find another kit, in this condition, with minimal mileage.
$4K; local pick up in the Bay Area, CA *heavily* preferred.
///M
Bummer about the spacer; these look legit.
Would love to have these but i just did a Porsche 996 conversion. There should be no worries about running a 12 mm spacer. I ran 12 mm’s all around on my M coupe w/Roadstar’s even before big brakes for a nice flush look with no rubbing.
bump.
///M
$3,800
///M
Sold.
///M
