Results 1 to 12 of 12
Thread: Z3 Front air dam
    Sep 2019
    Colorado Mountains
    2000 2.3 Z3
    Z3 Front air dam
    The front air dam on my car needs some work and the left and right pieces are shot. Is it necessary that they need to be on the car? I read something where is helps with cooling but just wondering...
    Feb 2019
    PA
    2001 BMW Z3
    Yes, help direct air for cooling and provides protection against rocks or other objects.
    Nov 2007
    Greater NYC Area
    '00 z3 2.5L & '98 740iL
    Motion Motorsports kit has been on my list of things to do:
    https://www.motionmotorsport.net/col...underpanel-kit
    Cheers,
    Phil
    Mar 2018
    Annapolis, MD
    98 M Roadster
    I’m looking to do a fan delete on my S52 Roady but all the lower front plastic bits are missing and I’m trying to figure out what to buy. The Mototorsports kit looks good but I think it will leave a gap under the radiator for air to by pass. Real OEM is confusing as far as part # s for this. White Z what is the part # for the picture you posted? As far as I can tell part # 51712491034 is the part I need but I can’t tell if it includes 51712496714. It looks like they are together in the photo you posted.
    Sep 2019
    Colorado Mountains
    2000 2.3 Z3
    The part I show in the picture is BMW # 51718397359
    The two ducts that attach to the side of that air dam are:
    The part that I show in the picture is
    BMW #51718397359
    There are two ducts that go on each side
    Right Side #51718401824
    Left Side #51718397357
    Mar 2018
    Annapolis, MD
    98 M Roadster
    Thanks for the reply. The photo looked like what I need but it seems the M uses a different part. Guess I’ll have to get one and see what it looks like.
    oskaloosa,ia
    '01 3.0 ZCoupe
    The difference between the M and regular Z is a z-bend to follow the M profile. It works just fine with the regular bumper, and is far superior to the OEM plastic piece.
    You can use the MM underpanel as is, you can also flatten in a bit in the front to make it a bit easier to install.
    Mar 2018
    Annapolis, MD
    98 M Roadster
    How close does the MM air dam come to the radiator? I have no plastic bits left under the front end. It looks like there would be seveal inches I would have to fill to force all the air through the radiator. 6FD2F2FB-76A3-49A4-AF46-5509E8CBAD51.jpg
    Dec 2019
    Powell, Ohio
    2000 BMW Z3 2.3
    White Z, I'm in a similar situation as you (in that i'm missing the front BMW air duct, part number 51718397359). The Motion Motosport kit pwhitt mentioned has also been something i've been thinking about (in part because its not plastic, and its cheaper). The transmission cooling lines are pretty exposed with any sort of protection it seems.
    I'd be curious what you end up doing, and / or if anyone has any experience with the Motion Motosport kit as a more affordable improvement.
    --e
    Sep 2019
    Colorado Mountains
    2000 2.3 Z3
    I put some J-B weld on the areas that were cracked and after it dried I used a very heavy industrial strength duct tape to cover over it then mounted it back on the car. It seems to work and it's holding.
    Quote Originally Posted by ///MRoadyJPL View Post
    Yes you will need to add ducting to fill the gap between radiator and MM panel
    Robb did something clever awhile ago and bent some flat stock to a triangle of the correct height (so it went to the radiator) and riveted it to the panel
    PRICE CUT on ALL FABRICS
    Dec 2018
    Indiana
    00 M Roady '22 Lexus RC
    When I got my car the under panel was missing also so I ended up buying .125 aluminum sheet and maked me a splitter. I had it powder coated in crinkle black.
  1. Z3 E36/7 WTB Front Air Dam & Bumper + Fog Lights
    By shotZee in forum Z3,Z4,Z8 Classifieds
    Last Post: 09-09-2012, 09:59 PM
  2. Any Interest in 320i Sport Front Air Dams?
    By G.J. Dixon in forum 1975 - 1983 (E21)
    Last Post: 09-07-2004, 11:29 PM
  3. My Zender Front air dam has to go who wants it?
    By ekdemos in forum BMW Parts Wanted
    Last Post: 06-14-2004, 10:24 AM
  4. Front air dam
    By Rel44 M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-01-2002, 01:14 PM
  5. Question Regarding ///M3 Front air dam
    By crnchyfrog in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2002, 07:58 PM
