Results 1 to 4 of 4
Thread: Droppped bolt into Cylinder Head
    Mar 2020
    Indianapolis, IN
    1999 BMW M3
    After recently purchasing an E36 M3 I was told there was a leak in the valve cover gasket. After removing the valve cover gasket, it seemed to be in excellent shape, and the source of the leak being an untightened bolt connecting the cylinder head and the block. When I tried to take the bolt out, I accidentally dropped it into the cylinder head, I cant find it and I'm not sure what to do. What should i do to find it, could it have left the cylinder head, and what damage can it do to the engine if I try to start it?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Find it. Fish around with a magnet stick. Probably just covered with oil and not visible. If you dropped it down the timing chain hole that could be an issue. You would want to look down the hole to make sure is is not stuck in the chain or in a guide or sprocket. If it is on the bottom of the pan, it might just stay there or you can pull the pan. Not super easy but not impossible and there are DIY.
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    How did it fall into cylinder head? What bolt? Where? I'm missing something.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    yeah, strong magnet on a stalk is your friend ... but we need more info. Which bolt, where did it fall? pics?
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
  1. Broken Bolt in Cylinder Head
    By andy81563 in forum 1996 - 2003 (E39)
    Last Post: 08-10-2014, 12:04 AM
  2. Head bolt ? on cylinder head on trackcar
    By 325Trckslt in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-11-2013, 11:17 PM
  3. NEED: One cylinder head bolt washer for S50
    By Eric1H in forum BMW Parts Wanted
    Last Post: 08-08-2006, 09:02 PM
  4. Help with an E8 torx bolt on cylinder head
    By turnerNCM3 in forum Forced Induction
    Last Post: 07-23-2006, 07:09 PM
  5. Cylinder Head Bolts
    By atakm in forum 1992 - 1999 M3 (E36)
    Last Post: 05-25-2006, 09:01 AM
