Results 1 to 7 of 7
Thread: N55 6MT transmission whine
    Aug 2019
    Europe
    M135i
    Hi
    I have a whine that's pissing me off, mostly audible in 1st and 2nd gear. Gearbox is a manual ZF 45 DZ on a F20. The whine goes in a higher frequency when deceleratin and it stops when shifting to neutral or, if in gear, when coming to a full stop.
    When I press in the clutch I can hear the part with the whine changing it's speed a bit, but it's still spinning until I come to full stop.
    Car has a new clutch and M3 transmission mounts which I guess lessen up a bit the sound insulation, but I remember hearing the whine with stock mounts as well. Also, Active Sound Design is turned off, so every mecanical sound is pretty loud.
    The input shaft bearing had a bit of play when I changed the clutch.
    So what do you think is at fault here? Is there any change this is something NOT inside the transmission? Is this sound normal for 85.000 km transmission? Could it be the differential? Would be an awesome excuse to get a lsd...
    Here is a clip with the sound:
    https://www.youtube.com/watch?v=y2t0...ature=youtu.be
    Thanks a lot
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Have you check the fluid level? Has the transmission fluid been changed? It’s a ZF transmission so contact ZF to ask about which fluid is needed and the fluid capacity. Or, go to the local dealer. Changing the fluid would be my first step.
    Aug 2019
    Europe
    M135i
    Ops, forgot to mention the most important part.... I did change the oil about 5000 km ago with OEM, to required capacity (full). I could not see any leaks, but the old fluid was looking awful. Would you say this noise level is out of ordinary, Marco? Do you have a manual as well?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Ok, scratch changing the fluid. Yes, I’m on my 5th bimmer, all manuals.
    Aug 2019
    Europe
    M135i
    A man with great taste! So all of them of them transmission were silent?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Yup, none of the transmissions were noisy. That loose input shaft worries me. How loose was it? It could be the input shaft bearing.
    Aug 2019
    Europe
    M135i
    The mechanic who changed my clutch said it had play within the limits. Can't say what limits...
    I would expect more noise on neutral with the clutch up, if this bearing would be the cause, but the noise is within norms for a manual car, I'd say...
    I suppose you can't just change the input shaft bearing, anyways, right?
  1. Transmission whine, post fluid change, 5HP30
    By system11 in forum 1995 - 2001 (E38)
    Last Post: 11-01-2006, 06:27 PM
  2. Standard Transmission Whine?
    By Everett#2390 in forum 2001 - 2006 M3 (E46)
    Last Post: 04-21-2006, 06:16 AM
  3. Transmission Whine, I think.
    By blueMRoadster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-29-2006, 03:26 PM
  4. 318iS "transmission whine"
    By ketchup in forum 1975 - 1983 (E21)
    Last Post: 10-12-2005, 05:14 PM
  5. Transmission whine fixed
    By POPS in forum 1995 - 2001 (E38)
    Last Post: 05-24-2005, 08:23 PM
