Results 1 to 9 of 9
Thread: 2003 BMW M3 wont start... dunno what to try next
    Jan 2005
    Oklahoma City
    s52 e30, e36Ms, e46M
    Back story - care would not start from time to time, mainly during summer or hotter times. Only gets driven a few times a month. If it wouldnt start I would repeatedly smash the clutch (3-10 times) and it would eventually start. This went on for about a year until it would not start again. When i try to start all the lights come on, fuel pump is humming, does not crank what so ever.
    I first tried bypassing the clutch switch, no change
    I replaced the clutch switch, no change
    at this point I assume the alternator, replaced with new and still doesnt start.
    I only have one key to the car
    Im lost now and not sure what to try next, I was 99% it was either the clutch switch (since it would start after smashing it) or obviously the starter...
    Any suggestions or advice?
    Thanks,
    Speedster
    Check out my details and paint corrections!
    www.theautospallc.com
    Apr 2012
    miami fl
    2002 bmw m3
    Sounds like ews. Clear all codes in memory unplug battery for an hr.
    If that doesn’t work and you can jump start it then my theory is right and you will need ews replaced and programmed for your car. Or used ews with keys. Or disable ews immobilizer all together. Had this issue before.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Have you pulled codes yet?
    I think the clutch is just a fluke, so scan the DME for codes as it sounds like you have a soft failing fuel pump.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jan 2016
    Ca
    2001 525it
    Try another key
    Seattle
    Aston Martin, E46 M3, X5
    I would say EWS. First check to make sure the connectors are secure.
    Dec 2013
    Chicagoland area
    EXOTICS
    The fact that it would sometimes start, along with your clutch pounding,
    leads me to suspect the starter-more specifically the starter solenoid atop the starter.
    Have a friend attempt to knock on the starter with a wrench while you simultaneously turn the key.
    Come back and post your results. A good first step before attempting more difficult diagnostics.
    Apr 2012
    miami fl
    2002 bmw m3
    Man the easiest way to diagnose is push starting it, if it runs after and does not turn on the it is not the ews or fuel pump and it is your starter.
    Sent from my iPhone using Tapatalk Pro
    Dec 2013
    Chicagoland area
    EXOTICS
    dtmjc,
    as we say in the hood,
    "The Man with the Plan"
    Thanks for the obvious info!
    Jun 2020
    Ottawa,ontario
    2002 bmw m3
    Hey guys I'm new to the forum thing I have a serious problem my e46 m3 needed a boost so I got lazy used another spare battery to boost it and it kept sparking on my m3s battery in the trunk so I forced it on and it started smoking now on the first switch position I see the engine light is on car cranks fine just wont turn over im thinking its a fuse but I need help. What did I BLOW.? I know it may not be relatable to your forum posts but I need help.
  1. 2003 BMW M3 Coupe - Imola Red, 5k miles, FLAWLESS!
    By Jeremy@TLD in forum BMW Cars For Sale / Wanted
    Last Post: 07-16-2004, 10:43 AM
  2. m3 wont start
    By daz95m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-10-2004, 12:32 AM
  3. FS: 2003 BMW M3 w/ Tubi Exhaust & Brembos! (pics)
    By E36M3 in forum BMW Cars For Sale / Wanted
    Last Post: 11-01-2003, 10:33 PM
  4. Look 2003 Bmw M3
    By mikec in forum BMW Cars For Sale / Wanted
    Last Post: 01-30-2003, 12:43 AM
