I wouldn’t keep driving the car at 20+.
Tell us about your maf and do you have vacuum leaks?
My maf is fine, not throwing any error codes, and the reading are within normal range. I have not done a smoke test because I wanted to see the fuel trims first. I don't think its a vacuum leak because the STFT are normal and stay normal with load. Plus the LTFT doesn't drop with load.
Ok start smoking testing all points.
What brand of fuel pump?
How many miles does the car have?
What codes?
Are the pre-cat o2 sensors original?
How many miles on the CCV?
how did you test the MAF?
high ltft is a problem regardless of stft. Yours are astronomical.
and your pictures don’t seem to be loading
