eBMWParts
Results 1 to 2 of 2
Thread: Stacking spring pads M Roadster
    Jan 2019
    Massachussetts
    2000 M Roadster,e46 325i
    Hi, I wanted to raise my M roadster slightly after doing H&R springs a few months back. The rear sits slightly lower.
    My question, I don't think has been addressed before or I'm having a tough time finding it. I decided to add a second 7.5mm pad, cut out the center to slip over the bump stop of the original one, and installed above the spring. I like the ride height now but I am second guessing and just want to be sure.
    The stacked pads fit securely and the spring still has footing on the nub.
    My question is for those doing this, is it proper to stack the pads above the spring or below? Does it matter, and if it does could you explain why?
    Thanks!
    Dec 2013
    Chicagoland area
    EXOTICS
    The rear springs should be able to accept both upper/lower pads.
    Why not install a single lower 15mm pad?
  1. Stacking spring pads, quick question
    By pelotudo in forum 1992 - 1999 M3 (E36)
    Last Post: 08-24-2007, 03:45 PM
  2. How Many Spring Pads can i stack up?
    By CHAMBMW in forum 1992 - 1999 M3 (E36)
    Last Post: 05-27-2004, 10:13 PM
  3. Stacking front spring pads
    By hccyong in forum 1991 - 1999 (E36)
    Last Post: 10-13-2003, 11:31 PM
  4. NE1 Have Problems After Stacking Rear Spring Pads?
    By Gene V in forum 1992 - 1999 M3 (E36)
    Last Post: 01-27-2003, 01:51 PM
  5. Rear Spring Pad part #
    By hyperknight in forum 1992 - 1999 M3 (E36)
    Last Post: 08-13-2001, 11:00 AM
