Results 1 to 10 of 10
Thread: Roof codes confusing me
    Apr 2020
    Aldwick uk
    BMW e46 325 ci
    Have a set of codes from my convertible e46 msport roof module (CVM) used inpa software to retrieve them.
    0x000012
    0x000013
    0x000017
    0x00001E
    0x00001A
    0x000023
    0x000024
    0x000025
    0x000027
    0x00002F
    These codes are all from the CVM
    The roof button is flashing constant red and if I time it right I can eventually get the roof down but it's in stop and starts and the same with closing the roof.
    Hope someone can steer me in the right direction. Thank you.
    Oldham UK
    '00 330i Sprt '92 525i
    Don't have a convertible but from my fault code list:
    12 Open control button permanently active
    13 Close control button permanently active
    17 Position switch for main pillar, short circuit to ground
    1E Switch, cowl locked, voltage undefined
    1A Switch, convertible-top comp. lid, voltage > 2.5V
    23 Switch, convertible-top comp. lid, right, locked, voltage > 2.5V
    24 Switch, convertible-top comp. lid, right, locked, voltage undefined
    25 Switch, convertible-top comp. lid, right, locked, short to ground or open circuit
    27 Switch, convertible-top comp. lid, left, locked, voltage undefined
    2F Switch, hard top, voltage > 2.5V
    Link to CVM manual:
    https://www.bimmerforums.co.uk/attac...ual-pdf.20920/
    HTH
    Jan 2016
    Ca
    2001 525it
    The faults are only trail markers to lead you in a certain direction for repairs, certain problems could set many faults as in the top system there are many micro switches for instance that need to work correctly before the top operates or a broken wiring harness on the left side of the top frame. But some faults like coolant temp to low could mean the thermostat is bad. In your case the top is a bit more involved than that
    Dec 2008
    Washington, NC
    01 330 CiC, 05 X3 3.0
    I'd say #1 is to check out the wiring that runs along the left side of the top frame at the first bend.
    Jan 2016
    Ca
    2001 525it
    Yup
    Apr 2020
    Aldwick uk
    BMW e46 325 ci
    Well I've checked all wiring and contacts and continuity of wires with a meter.
    Read through the e46 roof manual and test at the end.
    Still no further on.
    The switch is flashing like the roofs not locked in position and I can eventually get the roof down stop starting it which I shouldn't be able todo if there is a fault somewhere. The manual says it will complete an operation if a fault occurs then stop to prevent further damge. So I shouldn't be able to get the roof down at all.
    Looks like I will be off to BMW after lockdown. Which grinds so bad because the nearest dealer is the same dealer that knocked the car off the ramp a few years ago.
    Let's hope they are more careful.
    Dec 2013
    Chicagoland area
    EXOTICS
    I would replace the button/switch first,
    Have you shorted it by maybe spilling something on it?
    cowichan bay, bc, canada
    06 330ci zhp convertible
    And reset the trunk convertible top compartment.
    Jan 2016
    Ca
    2001 525it
    Also check the wiring going into the the trunk lid
    May 2020
    Mooresville, NC
    2004 BMW 330Ci
    How do you reset the trunk convertible top compartment?
  1. Radio code confusion
    By Mad Cow in forum 1991 - 1999 (E36)
    Last Post: 01-26-2010, 09:47 PM
  2. code confusion with the peake reader/reset
    By Devo540 in forum 1996 - 2003 (E39)
    Last Post: 01-21-2010, 06:46 PM
  3. Replies: 0
    Last Post: 01-18-2010, 02:56 PM
  4. Chassis code confusion
    By Rallyincali in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-18-2008, 01:45 PM
  5. Code Confusion - Need Advice
    By Fly N Drive in forum 1991 - 1999 (E36)
    Last Post: 01-05-2006, 07:57 PM
