Results 1 to 7 of 7
Thread: Relocate fan behind radiator.
    Apr 2020
    Norway
    BMW E46 320D
    Hello I am trying to mount a bigger intercooler on my car. I went for the airtec one, but the problem i am having is mounting the fan behind the radiator as the fan will not fit when using the new intercooler. I was trying to see any logical way to mount the fan, but i am unable to find anything that i can mount the fan in. One thought i am having is cutting the edges of the fan to try and fit in inside the radiator shroud. But i am not sure if that is the best solution.
    a few pictures.
    https://ibb.co/FDdfX9H
    https://ibb.co/XW9D0LD
    https://ibb.co/89zvSS5
    https://ibb.co/f8GqJ1V
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Not sure if your diesel model is the same but on the gas cars if you got the automatic transmission, the car came with a belt driven clutch fan behind the radiator and an electric auxiliary fan in front of the condenser. A similar car with a manual transmission had only an electric fan behind the radiator. Many people eliminate the belt driven fan and shroud and replace it with the manual transmission fan assembly, which is a simple drop in replacement.
    Sent from my S61 using Tapatalk
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    One of the pix dies show a rather large fan with the clutch on the front of the engine. You seem to have plenty of space between the radiator and the engine. Perhaps if you remove the existing mechanical fan you’ll have enough room.
    Apr 2020
    Norway
    BMW E46 320D
    Well i have read about the single fan modification. But i kinda want to have both the OEM fans there. I live in Norway which is a pretty cold country in the first place, so temps shoudnt be that bad. A friend of mine has the same car and his AC fan has never worked :O
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Have your friend read this: https://drive.google.com/file/d/1Cac...BTPQDJx6u/view
    Youre in Norway so a single fan is probably fine.
    cowichan bay, bc, canada
    06 330ci zhp convertible
    I can confirm the clutch fan removal on a 2002 BMW 325 CI I have not used it in over five years and live in BC Canada near Victoria. I’ve never even heard the electric fan turn on once during operation of the car even in the summers.
    Dec 2008
    Greenville, NC
    99 740iL, 01 330 CiC
    I deleted the engine driven fan fan in my former e36 325 and it had no problems overheating in eastern NC, where it can get 100 degrees in the summer with high humidity. Sold the car with 280k miles on it. My current e46 (330, manual transmission) never had an engine driven fan from the factory.
  1. Fan rubbing radiator
    By cipher982 in forum 1991 - 1999 (E36)
    Last Post: 05-10-2006, 01:15 PM
  2. e36 m3 ac fan and radiator
    By fred spencer in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 03-15-2006, 08:12 AM
  3. Need : e36 hood passanger fender zkw fan for radiator
    By yepp in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 12-28-2005, 01:20 AM
  4. engine fan blew, radiator owned.
    By CrazedBMW in forum 1991 - 1999 (E36)
    Last Post: 07-26-2005, 03:09 PM
  5. WTB: fan for radiator '96 328i
    By lazarost in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 07-08-2004, 11:48 AM
