Results 1 to 3 of 3
Thread: Help adjusting damping on generic coilovers
    Jun 2019
    San Jose
    1995 m3
    I know, this is gonna be a general question. Obviously not all coilovers are created equal and there's a lot of factors involved such as tires, spring rates, alignment, sways, etc... But I would like to know how the damping should be set on my k sport 36 way coilovers or as a matter of fact any other budget off-the-shelf coilover which adjusts compression along with rebound like many other affordable coilovers in the market like BC's, D2's, megan racing, etc. I know with these cheaper solutions the damping adjustment isn't linear so there is no magic number to set these at, instead I'd like some advice from knowledgeable members on how one should set up these kind of coilovers up for spirited driving and track days.
    The instructions on my coilovers said to set the up halfway towards stiff and make further adjustments from there, so I tried that and the car felt good, but a little over steery mid corner where the car seemed like it wanted to keep turn more than the input I gave, also I noticed the rear felt light and very willing to rotate under heavy braking. so I took some advice of setting up the front stiffer than the rear on a RWD car, and now I'm getting slight understeer which I feel like is safer on a street car. But since the local track is closed I am unable to tell what the faster set up is without times... So being curious I turned to the forums and found surprisingly little info on how coilovers should be set up since most posts are regarding real coilovers and dual adjustable coilovers (the nice stuff like KW's, AST's, GC's, etc.) I know I'm not the only one stuck with coilovers with questionable damper quality so I figured I'd ask the experts here and maybe help some others along the way.
    In short, I have read the ride quality is strongly influenced by the stiffness of the rear dampers so one should set up the rear as firm as they can tolerate without jumping/skipping or wallowing over bumps. And then adjust the front to be equal and then fine tune the front from there to exhibit the desired qualities of slight understeer on corner entry, neutral mid corner, and slight oversteer under power at the corner exit. Does this sound right to you guys or am I going about this the wrong way?
    Thanks in advance! For anyone curious my current set up is a 95 M3 with 245/35r18 federal RSRR's, stock sways, 3.5 F camber, 2.5 R camber, zero toe F and slight toe in R
    ATL
    '91 325i
    If you want to have meaningful damper adjustments, you need to trash your K-Sports. They will dyno completely different from one another, some will have the max lower than the min of the second damper in a set. Plus the adjustment range is a joke. Most cheap coilovers are just that, cheap. BC is probably one of the better ones and seem to have an actual QC department.
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Quote Originally Posted by Pavlo View Post
    Have you dyno'd the Ksports ?
  1. Adjusting damping / rebound on ground control coilovers
    By RatseL in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-10-2015, 10:23 PM
  2. E30 bc coilover+hub+extend adjust damp and skid plate bearing e30
    By immajackuup in forum E30 Parts Classifieds
    Last Post: 06-29-2012, 10:03 AM
  3. Need help on my H&R coilover!
    By DINAN COSMOS in forum 1992 - 1999 M3 (E36)
    Last Post: 08-17-2010, 10:50 PM
  4. help with damping adjustment on ground control coilovers
    By konduktor in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 02-22-2010, 10:13 PM
  5. Replies: 2
    Last Post: 02-18-2010, 01:49 PM
