Results 1 to 17 of 17
Thread: 96 M73 Key Fob
    College Station, TX
    2005 BMW M5, 1997 850Ci
    96 M73 Key Fob
    I still have my original M73 Key Fob but I need a spare as is my only ignition key.
    What is the process for getting a spare key fob, cut and programmed? go dealer? locksmith? online?
    Wondering what are my options and what the cost may be?
    Is this link valid in terms of steps? https://bmw-key-replacement.com/bmw-...mw-rubber-key/
    Cheers and I appreciate the guidance
    Mar 2006
    Harrisburg, PA, USA
    x5, 640i, 850Ci, 850CSi
    Go to the dealer with your VIN and proof of ownership (BMW requires this, even if they know you), and they will order a key for you which will then have to be programmed according to the directions in the link. Those are the same directions I followed when I had to program one for my car, and they work pretty well. I don’t think a locksmith can cut a key for you, and even if they can, they can’t get you one with the electronics.
    Mike Barrett
    94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
    96 850Ci, Oxfordgrun over silbergrau hell
    May 2019
    St. Louis, MO
    1995 840Ci Cosmos Black
    The link instructions are correct for programming.
    You MUST program all your keys in the same session. Do not turn on the ignition for each key or you will start over and overwrite the already-coded keys.
    If you don't use your remote/alarm, a locksmith can cut a key without the transponder if they have the correct blank.
    Same goes for the valet key. If you need one of those and have a dead regular key, you can make one by filling the slot with JB weld or the locksmith can make a copy of one without the center grooves. (I know you didn't ask that, but I almost bought one from the dealer until the parts guy said something...)
    College Station, TX
    Thanks Dave. Quick questions please.
    if I get this key fob on eBay as per the link bellow can I:
    1. Program it myself based on the instructions?
    2. Have a local locksmith cut it for me after is programmed?
    https://www.ebay.com/i/262635551645?...SABEgLKAfD_BwE
    Sep 2011
    Vancouver Canada
    '91 850i, E39 & E46 Cars
    hsdady - I'm not 100% sure of this, but that eBay key (see link above) if it is a real BMW key with electronics can't be cut by any locksmith I know. Their key cutting equipment is not made for cutting that type of steel. And I have never heard of a BMW dealer who would cut a key that you brought to them. I'd investigate further before buying the key on eBay.
    Maybe others can chime in about this- Henry
    Jan 2014
    Huntington Beach, Ca.
    Tesla, Hummer H2, 840Ci
    Yes,
    Those eBay key work fine. I have bought 5 set on various Bmw car.
    E31
    E39 and
    E36
    Had a local locksmith cut them and follow that YouTube video and program them myself
    Sent from my iPad using Tapatalk
    College Station, TX
    Thanks Daves. Quick question here. When you say all keys, you mean I have to re-program even the existing / original key all over again? or just program the new ones? I don't want to screw up the only working key fob I have . THANKS
    Quote Originally Posted by DavesNotHere View Post
    Mar 2006
    Harrisburg, PA, USA
    You have to reprogram the existing key(s) as well, or they will stop working. AMHIK
    Mike Barrett
    College Station, TX
    Thanks much Sir. I am a CPA not a techie 😀 what is the likelihood to screw something up, like screw the only key fob I have? Can I repeat this procedures if it goes wrong? A bit nervous 😀.
    Quote Originally Posted by mbarrett635 View Post
    Jan 2014
    Very easy. That YouTube video walk you through step by step
    Aug 2019
    Tujunga, CA 91042
    850CI740Lsezd750L95sezd
    I just don't think anybody is getting much from a dealer right now. COVID . . . closed.
    College Station, TX
    Just to make matters more interesting there are 2 confusing listings on eBay for the same key and car, one with a 433Hz frequency and the other one with a 315Hz. Which one the heck it is They both look the same as my original key
    https://www.ebay.com/itm/262647065508
    College Station, TX
    So I source the 315Mhz keys from eBay and contacted a local locksmith to cut and program them. He seems very experienced.
    That being said he is telling me that as soon as he program my 2 extra key fobs the original one will get kicked out and it will not program as stated but some of you gents. That's his experience. Is he doing something wrong when re-programming the original key? I just don't want to lose the original
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    There are two parts of the key that are matched to the car:
    The transponder: This is supplied by BMW against your VIN when you purchase keys from them. More info here:
    https://www.meeknet.co.uk/E38/Key/Index.htm
    The remote transceiver: This can be programmed using this method (all keys must be programmed at the same time):
    https://www.meeknet.co.uk/E38/Key_Program.htm
    My BMW Repair YouTube Channel
    College Station, TX
    Thanks much Timm
    So can this local locksmith program my 2 keys, the transponder and the transceiver? Is it true that when they program the new keys the original one will stop working as it won't take the re-programming?
    Cheers and thanks mate
    This post I think it does provide some explanation which may be the same for the E31
    https://www.bimmerforums.com/forum/s...tarts-the-car)
    Aug 2019
    Tujunga, CA 91042
    Quote Originally Posted by CD05001CIA View Post
    Some dealers are coming back "online" opening with modified operating parameters [social distancing, hand washing, sanitizing, etc. ]
    College Station, TX
    I found a BMW dealer in Houston to do it for me. I got the original key fob and a valet for $275 all together. Not too bad. I still had to go through this sequence with both keys, new and original. It worked perfect
    Thanks everyone
  1. 96 M3 Key Fob
    By vincentjames501 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-13-2009, 12:46 PM
  2. ****************WTB E36 96+ Key Fob
    By Msilvia in forum BMW Parts Wanted
    Last Post: 06-08-2009, 08:44 PM
  3. ****WTB E36 96+ Key Fob and Alarm LED****
    Last Post: 06-06-2009, 01:18 AM
  4. FS: 2 Button key fob for the 96+ cars
    By M3BimmerBilly in forum Car Audio & Electronics
    Last Post: 08-05-2008, 01:19 PM
  5. Programming Keyless Entry/Alarm Key Fob Remote 96 328i
    By HurricaneX in forum 1991 - 1999 (E36)
    Last Post: 10-27-2006, 05:42 PM
