Hi
Having a problem getting the interior heater to work. Aircon is brilliant, bone chilling from 16C right up to 28C.
Checked all the relevant fuses but all ok. Any suggestions?
Tempest
Have you checked the stratification settings in the climate menu?
If you have no heat that is a water control valve under the hood on the left side
Also check your coolant level if it was low you would have no heat and if that was the case the you should look for a coolant leak
