OK next things next on the list of things to be done on my M20B20.
Since I got the car it has been running roughly and making a slight tapping (pinging?) noise towards the rear of the engine. It runs loudly and sounds like a tractor.
I've changed the timing belt and played with the ignition timing in addition to putting in brand new spark plugs and spark plug leads, changing the fuel filter and oil.
I fixed one leak I found in the vacuum lines. I haven't gone to the point of doing a smoke test. Is there anything I'm missing?
Here is a video. What does it sound like?
https://youtu.be/W8TRDyZoAyc
And when messing with the distributor timing
https://youtu.be/I7gQc_Dk_CM
Have you inspected the valve train?
I haven't yet, would that cause/rough running like this? I also doubt the injectors have ever been looked at but not sure if that's a potential factor
Sent from my U using Tapatalk
