I'd appreciate your input...
first photo is my front caliper... you can see half of the boot was coming off when i took the brake pads off.
Should i :
1. try to push it in with a smooth flat head or popsicle stick ?? (the other caliper had a small area i was able to push in but this is WORSE)
or
2. take the caliper out and reassemble? ( really dont want to do this but might have to?)
Bmw caliper gasket half off by zactastic, on Flickr
here is a photo from the links below, they took the piston out which you can then slide the lip of the caliper boot in easier
Screen Shot 2020-03-30 at 4.33.39 PM by zactastic, on Flickr
links: http://www.eatsleeptinker.com/2014/0...6-m3-calipers/
https://www.bimmerforums.com/forum/s...er-Rebuild-DIY
You should rebuild the caliper with a new seal and boot. Watch YouTube vids there are plenty of guides.
The kits are cheap. You can try to push it back in, but it won't stay.
Just get a rebuild kit and rebuild them all.
