Results 1 to 9 of 9
Thread: Power trains
    Mar 2020
    Halifax Canada
    2008 BMW 323, 2007 Mini
    Power trains
    Is the power train the same in a 2014 320 and 328 other than the difference in the engine power?
    May 2014
    Los Gatos, CA
    05 330i
    Yep both use N20B20 engine
    05 330i Alpine White
    Past:
    02 330i Titanium Silver
    R56 MCS
    00 540i6
    Jul 2004
    Houston, TX
    36 Cylinders
    Non forged pistons in the 320i and difference in software in the engine control module.
    It can be converted to 328i software, I've done a few, but it's not simple at all. It has some heavy protection against it.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mar 2020
    Halifax Canada
    Thanks guys.
    To be 100 % diff, transmission and 4 wheel drive system are all the same?
    Jul 2004
    Houston, TX
    36 Cylinders
    Hardware, maybe yes. Software is different between the two in transmission and transfer case.
    We need more exact info on each car... the differentials may have different gear ratios.
    -Abel
    Mar 2020
    Halifax Canada
    Thanks,
    I am not too concerned with the software or gear ratios.
    My worry is mainly the diff. My 323 is a Canadian only model and it uses a smaller weaker diff than a 328 of the same year which make it likely to fail at a lower mileage.
    I don't want to be in the same position if I get a 320.
    Jul 2004
    Houston, TX
    36 Cylinders
    Try https://www.realoem.com/bmw/enUS/select
    parts system. It will give you which models the differential and things were used on. For USA models, the 320i and 328i used the same exact differentials.
    -Abel
    Mar 2020
    Halifax Canada
    Great site, Thanks for all the info.
    Quote Originally Posted by Alvin323 View Post
    Thanks,
    The rear differential is the last thing you need to worry about with a modern day BMW. The diff is probably the least likely thing that will ever break in an F30.
  1. Bad vibration in 06 530i Power Train
    By tsmullins in forum 2004-2010 (E60,E61)
    Last Post: 04-12-2013, 03:20 PM
  2. Power Train Oil
    By KdragonXhunter in forum 1991 - 1999 (E36)
    Last Post: 04-03-2012, 12:49 PM
  3. 1995 530 5 Speed Power Train
    By jeffcfp1 in forum 8 Series (E31)
    Last Post: 02-19-2011, 06:22 PM
  4. Is the Power Train or Silver warranty worth it?
    By GatorKallick in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-19-2010, 12:29 PM
  5. power train upgrade or just get a 635
    By berry in forum 1976 - 1989 (E24)
    Last Post: 09-26-2006, 12:32 AM
