Results 1 to 5 of 5
Thread: E32 automatic transmission revers only
    Mar 2020
    Denmark
    E32
    Hello iam New here.
    Iam locking on a e32 750 1988 250.000km
    The seller say no forward gears. Any ide??
    MauiM3Mania's Avatar
    MauiM3Mania is online now Observer/Master Skeptic Moderator
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved to the model specific sub-forum.
    88M3 AW 43k miles Project FS
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    reverse only https://www.europeantransmissions.co....BMW/92-12.pdf
    Read my fault finding table http://twrite.org/shogunnew/diagnosis/gearbox.html
    Often, a failed A-clutch will result in no forward movement, with reverse still working.The A-clutch parts can be replaced fairly easily, without any special tools (once the transmission is out). However, if you are paying labor in removing the transmission, it may be wiser to just do a full rebuild and start fresh on everything. Additionally, we are not certain that the fault is just within the A-clutch assembly. A master rebuild kits include modified parts to rectify the A-clutch issue.
    http://www.e32-schrauber.de/bmw/date...er_Winfred.pdf
    No reverse:
    -wrong setting of gear change rods between control lever and gear box
    -dirty oil filter
    -clutch B destroyed, in this case no third gear
    -clutch D destroyed, no engine braking in position 1, 1st gear
    -clutch E destroyed, no engine braking in 2nd and 3rd gear, also in position 1 , 1st gear
    -reverse gear safety valve faulty
    slipping or shaking at start in reverse
    -clutch B or E brake D defective
    Fault: position D, no drive possible cause:
    dirty oil filter
    clutch A defective
    one way clutch 1st gear slips
    https://www.bimmerforums.com/forum/s...-forward-gears
    you have to remove the trans pan, check the ATF if it is dirty, if it smells like burnt, if there are metal particles, check and overhaul the valve body. Is the selected gear shown in the instrument cluster? Is the cable between the gear handle and the lever on the side of the transmission correct adjusted, broken?
    When you consider working on a ZF automatic, your starting point should be the tag, which leads you to the information and application required for the unit.The first line of the tag is the serial number, which is required to identify which running changes or modifications might apply.
    The second line, the part number (stucklisten), is often the most important number. The first four digits of this number identify the type of transmission. For example, the 1019 is 4HP20, 1043 is 4HP24, and 1056 is 5HP18.
    The next three digits of the stucklisten identify a design type, such as 000, 010, 020 or 030, telling you if there is a transfer case, electronic control or special application. For example, if the tag says 1043.030, it is a ZF4HP24. If it reads 1060.50, you know it is a ZF5HP19 specific for Porsche.
    The last three numbers identify the application. If the tag reads 1058.000.026, it means you have a ZF5HP24 RWD Jag41 (AJ26).
    Some tags include the part number from the car manufacturer that uses this type of transmission. For example, NNE4400AA equals Jaguar.
    Because there are so many applications worldwide, the tag numbers are an important way to ensure you order the right parts.
    Nov 2019
    cincinnati
    89 750IL
    I vaguely remember a check ball issue causing reverse only
    The ball wears and won't seal the port
    Jan 2005
    Japan
    Here are some frequently asked questions regarding the ZF 4HP22/24 automatic gearbox.
    My Autobox is now only able to select reverse. Why?>>>> Your A clutch (forward drive) has failed and you will require a replacement autobox.
    I have just fitted a rebuilt ZF gearbox but the gear shifting speeds is nothing like it used to be. I have to rev the engine really hard to make it change up. Why?>>>>>>Check the setting of the kick down cable, if it is too tight the gearbox will think you have more throttle applied than is the case. Check and adjust the gearbox accordingly. As a guide the looser the cable, the earlier it will shift, visa versa the tighter the cable, the later it will shift.
    What oil should I use in my Auto ZFHP22?>>>> We recommend you use AFT Dextron 2/3.
    What is the oil capacity of the ZF 4HP22 ?>> Oil change approx 5 Litres (note from shogun, this refers to Landrover/Range Rover, ATF pan is different size from BMW) .Dry fill approx 9 Litres
    I have just fitted a reconditioned ZF autobox. I have filled the box with the correct amount of oil but have no drive at all, forward or reverse. Why?
    The first thing to do is to remove the oil cooler pipe from the bottom of the gearbox (put a container under the open end to catch the oil) and start the engine. You should get a good flow of oil. If not the pump has been broken during installation and will need replacing/rebuilding. The torque convertor must be fitted to the gearbox, located correctly on the pump and locked into position before the gearbox is offered to the engine, otherwise damage will occur to the pump, resulting in no oil flow and subsequent to other parts of the autobox.
    When I start my Automatic Range Rover in the mornings it takes a while to engage drive, it has not always done this. This has become worse in the cold weather. Why?
    It sounds like you need to change the filter! In the cold weather, i.e when the oil is cold and more viscous, if the filter is partially blocked it will take some time for the pump to draw oil through it. Once the oil becomes warm it flows more freely and can pass through the filter more easily. Hence the problem only occurs when the oil is cold. To remedy this problem your filter needs to be changed. This should be done sooner rather later to reduce the possibility of damage to the autobox, by the clutches ‘slipping’ during this slow engagement.
    I have a 4sp ZF, when I select “D” the vehicle won’t move, when I select “1” the vehicle moves off. I can then select “D” and continue to drive normally. If I stop I have to start in first again. Why?
    A sprag clutch has “inverted” and will need replacing. No further damage will occur if you continue to drive but you will need to select “1” every time to start moving. A rebuild is required to correct this.
    I have a 4 speed ZF Auto and it sticks in first gear in the morning or when cold and is reluctant to change up from 1st gear. Once the gearbox has warmed up it shifts normally. Why?
    The governor valve is sticking, which can be caused by contamination. i.e. clutch plates or other parts disintegrating. The fine debris finds its way past the filter and tends to accumulate in the governor, causing it to stick. A temporary solution is to remove and clean the governor. The problem will often recur as debris from damaged parts continues to build up in the governor. If the problem continues after cleaning the governor then it may be necessary it replace your Autobox.
    We have noticed many customers reporting this fault starting a few days after an oil and filter change and after researching this using our experience and the expertise of others in the trade we have come to the conclusion that as ATF oil is a detergent type oil, when the oil is changed this will dislodge and stir up settled debris in the autobox which in turn jams the governor valve. In light of this although it sounds controversial it is debateable if changing the oil and filter is a good idea, some say if the box it going to fail it will fail if the oil is good or bad and their advice is leave it alone. I am still undecided but the truth is I get a lot of calls from customers thinking they are looking after the autobox by servicing it and a few days later this fault occurs.
    I have a range rover classic with V8 and ZF autobox and I want to remove the V8 and Fit a 300 TDi,
    There are 3 ways to do this,
    1) fit the whole stock 300 disco auto setup complete, this is the easiest option.
    2) get the 300 auto backplate, flexplate, starter ring gear, converter and bellhousing and fit these to the V8 ZF, be careful not to break the pump.
    3) contact www.mdengineering.co.uk and buy a adapter fit to fit the V8 ZF to the 300, this allows you to use the bigger V8 converter which is desirable over the smaller 300 one.
    The above frequently asked questions are courtesy of Ashcroft Transmissions.
    http://blog.paddockspares.com/zf-4hp...ked-questions/
  1. E32/Automatic Transmission fluid drain
    By Mike Sanchez in forum 1988 - 1994 (E32)
    Last Post: 01-23-2022, 09:28 PM
  2. E32 Automatic transmission drain plug torque
    By mpj008 in forum 1988 - 1994 (E32)
    Last Post: 05-14-2013, 12:18 AM
  3. Automatic transmission in E34 535i and E32 735i...
    By SeanH in forum 1988 - 1994 (E32)
    Last Post: 01-15-2010, 10:55 AM
  4. Replies: 3
    Last Post: 01-04-2009, 07:01 PM
  5. Question about E32 automatic transmission
    By Hound in forum 1988 - 1994 (E32)
    Last Post: 01-05-2007, 01:22 PM
