Results 1 to 3 of 3
Thread: Recoding used DSC control unit on e46 M3
    Mar 2020
    Oakland, CA, USA
    2001 BMW M3 coupe
    The problem: DSC control unit failure and not being able to pass the e-smog in California. Does anyone know if a re-coded used replacement will enable me to pass the e-smog test? TIA...
    Mar 2020
    Oakland, CA, USA
    2001 BMW M3 coupe
    Maybe this will help clarify. I was told by one BMW guy that when the ABS/DSC unit fails I'd never be able to pass a smog test and he recommended an OEM replacement at about $1700. Then I was told by another BMW guy that he'd never heard that a failure of that unit could be the reason I can't pass the smog check. Conflicting information. Hoping someone who's had a similar issue can chime in.. TIA
    So here are the fault codes:
    DME -
    (132) 84 DSC, CAN time-out
    (139) 8B Interruption, cruise control operation
    INSTRUMENT CLUSTER (KOM) -
    (245) F5 No CAN identification (ASC)
    ANTI-LOCK BRAKING SYSTEM (ABS) -
    76 Speed sensor, signal interference,
    73 Internal fault,
    88 Steering angle sensor, CAN
    Dec 2022
    colleyville tx
    2000 328i
    hello everyone,
    I have a 2000 328i. my ABS, Traction control and brake light is on. I went to an indy and he pulled codes and he said the DSC module needs to be replaced. the pump is fine, just the electronic module on the pump is bad. I found a used one ebay with the the same part number as mine. My module is setting on the passenger side close the firewall. Here are my questions. does anyone have a write up on how to remove the old unit (just the module and not the pump)? Please let me kno
    w. thank you in advance for any assistance anyone can provide please.
  1. E46 Ground Control Coilovers For E46 M3 Complete
    By e90dude in forum Suspensions, Springs & Shocks
    Last Post: 03-11-2019, 08:18 PM
  2. E46 FS: Ground Control Sway Bars E46 M3
    By Viper3812 in forum Suspensions, Springs & Shocks
    Last Post: 05-10-2012, 10:51 AM
  3. E46 WTB: ABS DSC Control Module for E46 Xi
    By nedined in forum BMW Parts Wanted
    Last Post: 06-16-2011, 11:02 PM
  4. Where's the yaw control on the E46 M3?
    By codemunky in forum 2001 - 2006 M3 (E46)
    Last Post: 01-22-2002, 02:12 AM
  5. Ground Control Coilovers for E46 M3
    By Kevlar in forum BMW Parts For Sale
    Last Post: 11-11-2001, 03:11 PM
