https://www.youtube.com/watch?v=XUSZjELY9lA
There are 2 videos to show the whistle noise. Iv made with AC on and off, and the noise still alive.
https://www.youtube.com/watch?v=Bu8W3OlR_Sk
Check the grill for a stuck whistle pig. They really start hollering when you go fast...
Sent from my SM-G970U using Tapatalk
Maybe the wife in the front seat (or the trunk?)
Roof racks up on the roof?
Look carefully for any loose trim. Tape the sunroof seam with painters tape. Look under for any loose plastic panels. Dont get a ticket while figuring this out.
My car makes the same noise at about the same speeds. It's the trim across the top of the windshield. It's getting slightly distorted from age and very slightly lifting at the back edge. Push it down or run tape across it.
I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
The law does NOT determine "right" from "wrong". They are unrelated.
If you put cheap parts on your car, you will soon have a cheap parts car.
Ahhh,..... Yeah, that is it, now that I think of it, I have a couple of RC composite airplanes that use the upper sections of the main wings as the hinge points for the ailerons, at high speed, when you make the plane roll, it whistles like crazy, very audible from the ground, when one aileron swivels up, it opens the bottom section up, and as long as the airplane is going faster than 65-75mph, it creates that whistle. We've clock them with radar guns, and at full throttle, the 100cc plane will hit 120mph, the 150cc version of the same airplane, an Extra300, I've had at 125, but that's really pushing the airframe a bit hard, but what a feeling!
i have to run tape outside ou inside of the car ? both ?
Outside, across the top of the windshield. Tape the back edge of the rubber strip to the roof. You can try to just push it down. I did that and after several tries it's way better. I purchased a new windshield trim strip but haven't installed it yet.
It only about $45 for an OEM one.
No.
Also check that all 4 jack pads are there and seated properly. A missing jack pad creates a whistle.
Ed CT
1998 528i
5-Speed
Aspen Silver
Aubergine Leather
No??? Ok, so maybe not..... I correct myself.
https://www.fcpeuro.com/products/bmw...SABEgLCT_D_BwE
No for that =D.
Yup, likely the top of the windshield rubber seal. I had the same thing years ago. I simply pushed it back in tight and it went away. If your windshield was replaced, they may have goobered up and have excess seal crap preventing the seal from fitting correct.
Also as mentioned, the jack pads being missing can make noise too.
I never knew that about the jack pads.
When the pad is missing, there is the mounting hole. Like blowing over the top of a beer (or other) bottle.
+1 on the jack pads...have seen that happen on 2 cars.
I’ll put the tape on it and test
Interesting that you got a whistle.
I had the front driver's side jack pad drop out and the result was a low rumble at highway speed. I first though I had a tire problem and then half convinced myself it was the front left wheel hub/bearing. The sound would even change a bit on a turn, although not as much as one would expect. However as soon as I noticed the missing jack pad and replaced it the "bad hub" cured itself. I suppose the change in sound during turning was a result of air flow over the jack pad pocket changing enough to adjust the tone and loudness of the resonance in the cavity.
I'm curious. Which jack pad(s) created the whistle for you?
(the distinction I'm making between whistle and rumble is in pitch rather than loudness. Same for you too?)
Regards
RDL
all jack pads are installed.
