Results 1 to 25 of 28
Thread: HELP, my 540i E39 make a strange whistle noise only at high speed ( 95MPH+)
    Mar 2020
    Brasil
    E39 540i 2003
    https://www.youtube.com/watch?v=XUSZjELY9lA
    There are 2 videos to show the whistle noise. Iv made with AC on and off, and the noise still alive.
    https://www.youtube.com/watch?v=Bu8W3OlR_Sk
    Oct 2016
    Atlanta
    2001 540iT
    Check the grill for a stuck whistle pig. They really start hollering when you go fast...
    Sent from my SM-G970U using Tapatalk
    Mar 2020
    Brasil
    E39 540i 2003
    Quote Originally Posted by rlordjr View Post
    ok, thnaks, but in the last time it was in good condition.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Maybe the wife in the front seat (or the trunk?)
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Roof racks up on the roof?
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Look carefully for any loose trim. Tape the sunroof seam with painters tape. Look under for any loose plastic panels. Don’t get a ticket while figuring this out.
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    My car makes the same noise at about the same speeds. It's the trim across the top of the windshield. It's getting slightly distorted from age and very slightly lifting at the back edge. Push it down or run tape across it.
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    Feb 2014
    Alexandria, VA
    Quote Originally Posted by Santaclaus4 View Post
    Ahhh,..... Yeah, that is it, now that I think of it, I have a couple of RC composite airplanes that use the upper sections of the main wings as the hinge points for the ailerons, at high speed, when you make the plane roll, it whistles like crazy, very audible from the ground, when one aileron swivels up, it opens the bottom section up, and as long as the airplane is going faster than 65-75mph, it creates that whistle. We've clock them with radar guns, and at full throttle, the 100cc plane will hit 120mph, the 150cc version of the same airplane, an Extra300, I've had at 125, but that's really pushing the airframe a bit hard, but what a feeling!
    Mar 2020
    Brasil
    E39 540i 2003
    i have to run tape outside ou inside of the car ? both ?
    May 2014
    Outside, across the top of the windshield. Tape the back edge of the rubber strip to the roof. You can try to just push it down. I did that and after several tries it's way better. I purchased a new windshield trim strip but haven't installed it yet.
    Feb 2014
    Alexandria, VA
    It only about $45 for an OEM one.
    Mar 2020
    Brasil
    E39 540i 2003
    No.
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by FernandoOliveir View Post
    No.
    No to what??
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Also check that all 4 jack pads are there and seated properly. A missing jack pad creates a whistle.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Feb 2014
    Alexandria, VA
    No.
    No??? Ok, so maybe not..... I correct myself.
    https://www.fcpeuro.com/products/bmw...SABEgLCT_D_BwE
    Mar 2020
    Brasil
    E39 540i 2003
    No for that =D.
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Yup, likely the top of the windshield rubber seal. I had the same thing years ago. I simply pushed it back in tight and it went away. If your windshield was replaced, they may have goobered up and have excess seal crap preventing the seal from fitting correct.
    Also as mentioned, the jack pads being missing can make noise too.
    Feb 2014
    Alexandria, VA
    I never knew that about the jack pads.
    San Jose, CA
    1997 BMW 540i 6 speed
    When the pad is missing, there is the mounting hole. Like blowing over the top of a beer (or other) bottle.
    Feb 2014
    Alexandria, VA
    Quote Originally Posted by edjack View Post
    I get it, I just never thought about it on the jack pads if they were missing.
    May 2014
    Quote Originally Posted by philly98540 View Post
    That's why I never installed the new rubber strip. I found that if I pushed the strip back down along the top edge of the windshield, the noise went away. It hasn't come back in a couple years. At least not up to 120...
    Jan 2015
    Shreveport Louisiana
    +1 on the jack pads...have seen that happen on 2 cars.
    Mar 2020
    Brasil
    E39 540i 2003
    I’ll put the tape on it and test
    Jul 2010
    Ontario, Canada
    2003 BMW 530i
    Quote Originally Posted by mattmar1 View Post
    Interesting that you got a whistle.
    I had the front driver's side jack pad drop out and the result was a low rumble at highway speed. I first though I had a tire problem and then half convinced myself it was the front left wheel hub/bearing. The sound would even change a bit on a turn, although not as much as one would expect. However as soon as I noticed the missing jack pad and replaced it the "bad hub" cured itself. I suppose the change in sound during turning was a result of air flow over the jack pad pocket changing enough to adjust the tone and loudness of the resonance in the cavity.
    I'm curious. Which jack pad(s) created the whistle for you?
    (the distinction I'm making between whistle and rumble is in pitch rather than loudness. Same for you too?)
    Regards
    RDL
    Mar 2020
    Brasil
    E39 540i 2003
    all jack pads are installed.
  1. Replies: 9
    Last Post: 11-21-2014, 09:09 PM
  2. PLEASE HELP!!! 1998 540i E39 intermittent starting problem
    By mjr2280 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-09-2013, 04:52 AM
  3. Strange Whistle noise
    By freethrowdunk in forum 1996 - 2003 (E39)
    Last Post: 08-09-2009, 11:32 PM
  4. Replies: 7
    Last Post: 06-06-2006, 10:09 PM
  5. HELP! My car is making a horrible popping noise!
    By rcM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-21-2005, 07:51 PM
