trying to find a abs ring for front right cv axel. it's an 2002 BMW X5 3.0i and I replaced the sensor and I think it's the abs ring but every time I look one up I don't get anything. I need help finding the abs ring because I need to do the front cv axels because there making noise and there both blown out
There is no ABS ring has such. The reluctor/tone ring is part of the wheel bearing.
Did you have the vehicle scanned? If so what are the fault codes from the ABS/DSC module?
Mark.
no but each time i plug the sensor in the lights go off but each time i press pedal and only when i try to go is when it feels like the front right break or something is dragging from that area and i tried to drive it and it flash the traction control and the X5 refuses to move when the sensor is plugged in
Get fault codes
