Results 1 to 14 of 14
Thread: E36- Stewart WP, S54 oil filter housing, high G oil pan, AMB tranX, M3 cams & MORE!
    Toronto
    1997 328is K20 swap
    Hello guys,
    My E36 build has been idling for a couple years. I recently decided I won't be using the M52 engine so these parts are for sale! I have shipping from Toronto, Canada to lower 48 + Alaska for great rates. I have lots of positive feedback on other car forums (NASIOC user 2JZ).
    Prices are listed in USD and do not include shipping or paypal fees.
    PHOTO ALBUM: https://imgur.com/a/C2L6oY5
    M3 cam shafts photos
    RARE 3.38 LSD SOLD
    Very low mileage, it looks incredibly clean for its age. Came off an auto M3 from Florida.
    $700 USD + Shipping & PayPal Fees
    S52B32 Cam Shafts $550 SOLD
    Great condition. M3 cam shafts photos
    m50manifold.com Conversion Kit $90
    This is the best conversion kit available to ensure no vacuum leaks. Uses a silicone hose, all stainless hardware, proper throttle body seal.
    m50manifold.com conversion kit is brand new in box.
    [pics pending]
    S54 Oil Filter Housing + AN fittings + Oil Cooler SOLD
    Oil filter housing is in very good shape with a newer gasket. Mocal copy oil cooler 9 row.
    NEW E36 BAFFLED OIL PAN SOLD
    Local BMW performance shop ACP performance built this for me. Their design is proven to handle the difficult high G track Mosport GP. I was told it exceeds the VAC & Achilles design. Brand new, never mounted. Fits M50, M52, S50, S52 ; OBD2 pan.
    New CSF radiator E36 $180 + Samco silicone hose kit $70 + Bimmerworld Electric Fan Conversion Kit $120 - ALL GONE, SOLD!
    Everything is brand new in box sealed.
    New Stewart Water Pump $120 SOLD
    never mounted, brand new in box.
    NEW E36 Metal Thermostat Housing with bung $25 - still available
    ($10 for metal thermostat with no bung) SOLD
    Best spot to measure water temperature. No bung thermostat available for $10
    ASC Delete Boot E36 $10
    Delete traction control, gain HP. OEM piece
    E46 M3 Engine Mounts $60
    brand new in box, OEM replacement engine mounts that fit all 6cyl E36 E46 and E9x.
    E36 accessory belt $10
    brand new
    E36 OEM rubber floor mats $40
    AMB TRANX 260 DP SOLD
    Direct power model, life-time subscription!! These are backwards compatible with the MyLaps transponders. Plastic mounting base is mostly broken off but this does not affect the function. I used 3M double sided tape.
    Jan 2016
    Chicagoland, IL
    2011 BMW 335d
    I will take the transponder. PMd.
    Oct 2007
    Louisville, KY
    1995 M3
    Feb 2013
    Kalamazoo, MI
    E34 540i6, E46 323i, E36
    Do you know if the M3 engine mounts would work for a 1997 328is?
    Atlanta, GA
    1999 m3 and 740iL
    Any idea what shipping for the m50 manifold + kit would be? Zip code is 30341
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Could you post part # from Stewart Water pump please? Seems like it may fit m54, if so I'm interested. Zip 01945 USA. Thanks.
    Toronto
    1997 328is K20 swap
    Quote Originally Posted by bimmerboy318 View Post
    Are your prices in Canadian or US?
    Prices are listed in USD.
    updated ad, this is now sold! thanks for your interest.
    Yup they sure would, these would be an upgrade actually. These were to go onto my E36 328is.
    Toronto
    1997 328is K20 swap
    bump.
    Nov 2018
    Miami
    1998 M3/4/5
    ...pm sent...
    Toronto
    1997 328is K20 swap
    Replied
    Jun 2008
    King City CA
    E36 328i 4 door mafia
    Motor mounts still available?
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    is that transponder still available?
    Toronto
    1997 328is K20 swap
    Update ad.
    Jun 2008
    King City CA
    Pm sent
  1. FS - S54 Oil Filter Housing(update your oil filtration/cooling on S50/52)
    By SneauxM3 in forum Engines, Performance Parts & Software
    Last Post: 08-07-2015, 12:04 AM
  2. FS - S54 Oil Filter Housing(update your oil filtration/cooling on S50/52)
    Last Post: 11-04-2014, 04:19 PM
  3. E36 S52 M52 oil filter housing modified for oil cooler - No Longer Available
    By grayracer in forum Engines, Performance Parts & Software
    Last Post: 10-28-2014, 07:27 PM
  4. S54 oil filter housing/w VAC oil line kit
    By C.Thurman in forum Race Cars & Track Parts
    Last Post: 08-10-2012, 04:59 PM
  5. Replies: 9
    Last Post: 05-04-2003, 02:35 AM
