Hey just putting a LS1 in my E36 and wondering if anyone else has used sikky mounts? If so can you post some pics of your transmission mounts. I cant get mine to line up.
Thanks Rob
I had a bit of a bitch getting mine to line up. Its a big help if you have either an engine hoist connected with tension on it or a trans jack under the trans so you can bolt the trans mount into the body then lower the transmission onto it. Cleaning up the threads in the body was a big help since mine were a bit crusty and made starting the bolts a bit difficult.
1999 E36 M3 Cosmo/Sand Beige LS1 swap
2022 G42 230i Thundernight/Tacora
