Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 61
Thread: 1999 E36 M3 LS1 and T56 swap - hpde / time trial
  1. #26
    May 2009
    San Francisco
    99 E36 M3
    So far I got the following advice:
    1. Clean it up and put it back together
    2. Change rings and bearings for sure at this point...along with the inspection
    3. Assuming that leave it as is. "Leave the carbon alone. More carbon = higher compression". my rookie brain doesnt even know if you are serious or not
    Anyone else? If I heard 18 out of 20 people say leave it alone that would be a good path to take. We are not there yet unfortunately.
  2. #27
    May 2009
    San Francisco
    99 E36 M3
    Not a lot of progress due to me not having 12pt socket to unbolt ARP rod bolt to inspect the red bearing. Had to order on Amazon.
    What caught me by surprise was the F-Body oil pan gasket being riveted to the pan. I drilled the rivets out. Preparing the pan for Improved Racing baffle installation. Ive read some mixed reviews on this part. Some undesirable results came from LS2. LS3 users I believe. Hoping that my LS1 will benefit from it on road course. I will have an oil pressure gauge for extra insurance. And will do some research on the warning light gauge options.
    I have also removed 1 lifter tray with lifters.
    Few questions:
    1. What is the overall opinion on this - do I replace lifters and/or trays?
    2. Is that normal to have all the imperfections on the inside of the Oil Pan - bumps/caking looking surface
  3. #28
    Mar 2004
    USA
    96 328is 6.0L
    I was the one with undesirable results from improved racing oil pan baffle. Had to drop pan remove it to improve my oil starvation issue on road course that it was supposed to “improve”. Luckily they were kind enough to take it back and refund me.
    As for inside of oil pan, they are rough castings and don’t look very nice from inside. Out of the ones I’ve seen yours look a bit on a rough side, but if there are no loose pieces, I wouldn’t worry much.
    Also, on the subject of oil pan, you might want to take out that long plastic oil level sensor as most likely you will not be able to reuse. It might be very difficult/impossible to do once on the car with headers. They sell blockout bolts that go instead of sensor and I think summit sells bolt with tapped hole inside it. I used it to re-thread for BMW oil temp sensor which I connected to euro m3 cluster. They have oil temp instead of mpg-meter.
  4. #29
    Sep 2016
    WI
    01 330Ci
    I'd spend some time over on LS1tech.com, there's a ton of great information about our engines over there. My thoughts so far:
    -If the engine was built by Lingenfelter you've got a great base to start.
    -You don't have Mahle pistons, you have Manley pistons. Pretty good stuff.
    -Jesel rockers are top notch. Since you've got good pistons and ARP rod bolts I'd verify whether you've got aftermarket rods or not.
    -I'd skip the LS6 PCV tube that goes from valley cover to intake manifold and fit an oil catch can in between the two, especially for road course work. I ended up going with the Radium Engineering LS setup, but there are a few other options out there that rate pretty well.
    I'm probably missing something. But keep the thread updated as you can, I like feeding off other ideas when possible.
    EDIT: I missed something. YES, absolutely replace the lifter trays. Lifters maybe/maybe not but they're not expensive and it's a "while you're in there." Also, I went back and forth on the pushrods when I built my engine. I bought the measuring tool and ended up just a shade longer than 7.400. I bought a custom length set from Manton, and got the 11/32 diameter with thicker walls for more stable valve train during track days.
  5. #30
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    I, too, was surprised at the roughness of the internal oil pan casting. But that seems to be what is normal!
    Diving in at the shallow end!
  6. #31
    May 2009
    San Francisco
    99 E36 M3
    Yes, I did refer to you as being the one with IR baffle issue I have been reading a lot on this in LS1tech forum and seems like overall results are good. But who knows, I guess I will have to validate myself.
    Got it on the oil pan imperfections. There is no damage to the pan so it should be good.
    Thank you for the tip on the oil level sensor. Ive searched and saw the plug with w/ 1/8 NPT Port that I might get.
    Quote Originally Posted by bimerok View Post
  7. #32
    May 2009
    San Francisco
    99 E36 M3
    I have been spending time on LS1tech.com including posting this progress thread over there. Not much feedback on it yet from LS crowd. Maybe BMW mention drives some away.....
    Good catch on "Manley" pistons, Ill edit the original post.
    As far as the rods go, where are the usual markings to identify the brand/part number? Visually I dont see anything on them besides the builder hand written build date.
    Thanks for the tip on the oil catch can, i'll do some research on it.
    As far as the lifters go - Summit has this "Summit Racing® LS Lifter and Guide Kits SUM-HTLSKIT1" https://www.summitracing.com/parts/sum-htlskit1. Anything against this? I am leaning towards GM original but this seems interesting. Will replace the lifter trays, that makes sense.
    On pushrods, id probably stick with current 7.400. Will verify the measurements.
    Thank you for the feedback, much appreciated
    Edit: This catch can seems ok - https://mikenorrismotorsports.mysimp...-oil-catch-can
    Quote Originally Posted by Matt330LS View Post
  8. #33
    Del a Where?
    LSx M3 & 2017 Touareg
    I'd always replace the lifters when inside the engine, it's cheap insurance.
    And I'd go with GM OEM LS7 Lifters we use them on 1,000+ whp builds at work no problem.
    Also the Norris catch can is good I also run one.
    Another question are you going to be running an Oil cooler?
  9. #34
    May 2009
    San Francisco
    99 E36 M3
    I was leaning towards replacing all lifters now based on the feedback. Is there a better source to buy all GM LS7 in a kit from than Amazon - https://www.amazon.com/GM-Parts-1249.../dp/B000QIUGNM? I cant seem to locate one that is not "out of stock".
    As far as Oil Cooler setup - I have followed multiple threads including your own setup.
    Few questions for you:
    - Adapter - how is your adapter holding up? This is the one I believe, correct?
    - Oil Cooler - I was going to go with ~40-42 row cooler based on the info many provide. What are your thoughts on THIS Improved Racing Setrab 40 row oil cooler? I do have to make sure im covered on track since thats the main use for the car.
    ---- Oil Cooler specs: 9.25" wide core (235mm), 40 rows or 12" (304.8mm) core height
    Quote Originally Posted by Bsaint View Post
  10. #35
    Del a Where?
    Try your local GM dealer if not try Keystone, Scoggin Dickey https://sdparts.com/ or https://briantooleyracing.com/
    The last we ordered was from Keystone they hadn't updated their pricing and we bought a BUNCH for $170.
    and yes that's what I used, I later switched it up to a sandwich plate to route the oil lines differently and I fitted a oil pressure sensor to it as well. No issues with it really I just didn't like the way the lines were.
  11. #36
    May 2009
    San Francisco
    99 E36 M3
    Hi All,
    Someone on LS1tech.com had mentioned the use of a crank scraper. Does anyone have any experience with this Improved Racing Crank Scraper and Windage Tray kit? Is it worth it/required? I am using IR oil pan baffle.
  12. #37
    May 2009
    San Francisco
    99 E36 M3
    I have received my 12pt socket set so I was able to remove the connecting rod bolts and check the bearings. This is the first time I am looking at the crank and bearings in any engine.
    How do you think they look?
  13. #38
    Del a Where?
    Curious as to how many miles were put on this since the original build, they look "okay" depending on mileage.
    Obviously they have some marks on them for sure.
  14. #39
    May 2009
    San Francisco
    99 E36 M3
    I was told 30K miles. And I think picture angles and lighting exaggerates the marks a bit.
    In addition, someone on LS1tech.com had mentioned that my rods have dowels therefore they seem to be aftermarket. I was looking for a way to determine if that was the case.
  15. #40
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    No Chevy production engine came with H-beam rods - they are definitely aftermarket.
    Can you catch a finger nail on the crank scratches? If not, new bearings ought to be a ok.
    The crank appears to be a cast item with narrow parting line - standard LS - likely production.
  16. #41
    Del a Where?
    OP, If in fact it has 30k on the build I think they look fine, but once again I'm not your engine builder/tuner so I would get the opinion of both.
  17. #42
    Mar 2018
    Arizona
    1998 328I
    great progress on the build so far! I took my car out to my first hpde event last month and had a blast, looking forward to see how this one comes along
  18. #43
    May 2009
    San Francisco
    99 E36 M3
    Thank you. Ive learned quite a bit from your build as well. Looks like yours is a blast.
    Quote Originally Posted by RulyLSX View Post
  19. #44
    May 2009
    San Francisco
    99 E36 M3
    Guys, question on my ARP connecting rod bolts. I have removed 4 of them to check the bearings. Can I safely reuse the same ARP 8740 bolts? I believe torqued to 45lbs (have to confirm). I do not have any bolt measurements prior to the first install and I believe they were installed only once.
    I have emailed ARP and they said that they have to be replaced vs most opinions state that its ok to reuse. Since I only removed 4 it would be nice to reuse of course but if its crucial to replace then I will have to.
    Any advice?
  20. #45
    Jul 2018
    Louisiana
    Bmw E39 528i
    I would just reuse them, I don't think they are torque to yield so they should be good to go a second time.
  21. #46
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Yeah his original post said it had speed pro bearings in it
    I was reference the connecting rod - it is an 'H' beam...all Chevy production engines were 'I' beam. It is aftermarket piece.
    Lifter trays: some aftermarket from China are defective. I buy many of my parts, even OEM from Summit - just locate the OEM part number. The trays keep the lifter positioned correctly, bad ones are loose and allow the lifter to turn sideways.
    ARP: Unless ARP gives a reason why, I'd certainly reuse. Maybe finding the torque values might be an issue. Use the proper lube as well.
    I'd do the lifters too...again Summit has them (OEM LS7 parts).
    Should be a fun build!
  22. #47
    May 2009
    San Francisco
    99 E36 M3
    Quote Originally Posted by mrallande5020 View Post
    Quote Originally Posted by Tim Mc View Post
    I believe rod bolts are around $100 so I will just buy a new set to be safe. Sounds like diagnosing the current bolt torque situation is more complex.
    I will also purchase a new set of LS7 lifters and trays. 2 options for this:
    Summit - LS7 lifters only - $260
    EBay - LS7 lifters and trays - $189 - direct from GM - AC Delco
    Any reason to believe the ebay ones are not authentic?
  23. #48
    May 2009
    San Francisco
    99 E36 M3
    Did some more minor work on Sunday.
    Drilled out the oem oil pan gasket and installed Improved racing baffle.
    Question on Oil Pumps. I have the oil pump that was installed - Lingenfelter LS1 modified GM Oil pump deburred to improve flow. But I have also ordered - Melling Performance Oil Pumps 10296 - from Summit. Can Lingenfelter pump be better in any way? Or swap to Melling without questions?
    Can not catch a nail on the crack markings at all btw
  24. #49
    May 2009
    San Francisco
    99 E36 M3
    I have received the following response from Improved Racing about the type of crank scraper model needed. Related to the type of rods that I have.
    • If they are factory rods: EGM-330F
    • Most aftermarket H-beam rods: EGM-331F
    • Some aftermarket H-beam rods that are beefier: EGM-332F
    ​​​​​​​I think the consensus is that my rods are not factory. But can they be "beefier" rod that they mention?
    Seems to me like
    EGM-331F should fit if I have a common H-beam rod setup
    Any thoughts? Thanks
  25. #50
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    I've never messed with a crank scraper except for buying an oil pan with it included/attached. I think you will find very low return on the install - it will be a benefit, but IMO not worth the effort. I recall reading it needs to be 'very' close the rotating assembly to be worth it - like using a dremel and fitting it to each rod/crank throw. Looking at IR website they only quote 2-4 hp...that seems statistically difficult to prove. Nonetheless...
    Crank: sounds like a simple polish is all that is required, if that. You can pop out the existing bearings and find what part number/thickness - replace with the same.
    Oil pump: I'd go with new - similar reasoning with the lifters. Admittedly, we patterned our build after an OEM Corvette engine - suitable for reasonable tracking at slightly above OEM horsepower levels.
    Ebay: I'm not a fan - you get what you pay for. One can invest a ton of money into the engine...when the engine swap is already a fairly big investment of time and complication. Reason we generally sided on OEM parts, at least on the initial go around.
  1. Alwaysbored786's E36 M3 LS1 Swap Build Thread
    By alwaysbored786 in forum Engine Conversions
    Last Post: 08-01-2018, 12:52 PM
  2. Attempting CA smog-legal E36 M3 LS1 swap
    By profplum in forum Engine Conversions
    Last Post: 06-04-2018, 02:31 PM
  3. 1997 E36 M3 with LS2/T56 swap - No Longer Available
    By jesh462 in forum 3 series & Z Series
    Last Post: 05-10-2016, 09:42 PM
  4. E36 M3 LS1 real world experience swap questions....
    By Steve91T in forum Engine Conversions
    Last Post: 10-06-2014, 08:51 AM
  5. E36 M3 LS1/T56 Conversion Harness - SOLD
    By EKnight in forum Car Audio & Electronics
    Last Post: 07-30-2014, 06:09 PM
