Results 1 to 25 of 61
Thread: 1999 E36 M3 LS1 and T56 swap - hpde / time trial
    May 2009
    San Francisco
    99 E36 M3
    Hi All,
    I wanted to start this thread in order to document my process of converting my track 1999 E36 M3 from S52 to an LS1 with T56. Ive been slacking on starting it for the past 4 years or so, especially since my S52 has held up on the road course without any issues so far (230K miles). Im not a pro at this by any means and I will not be able to create such exceptionally detailed threads like some of you do. But, if at least one user can get even a single valuable piece of info from my experience that is enough for me. Second reason is to possibly get some advice from the guys who have accomplished this swap already.
    I do want to say Thank You to all the contributors to this forum. Without Bimmerforums members help I would have never dared to take on a project like this.
    Having said that, if you see that I am doing something wrong - don’t hesitate to let me know.
    My overall goals:
    E36 M3 is a dedicated track car. HPDE and Time Trial. No plans to race so far. Just a fun weekend hobby. I do love the E36 platform and do like the idea of an American V8. So combining the two in a fun weekend toy project seems like cool thing to do. For me at least. I am sure not everyone shares the same views.
    Car
    • 1999 E36 M3
    Install Kit
    • CX Racing full install kit - Ive changed the bushings in the motor mounts to Energy Suspension (per another forum member recommendation) - bulk-2008 model
    Wiring
    • Wiring Specialties harness
    Drivetrain
    • T56 transmission
    • Remote bleeder setup
    • LS7 Clutch
    • Coleman Racing aluminum driveshaft - length 44.5in, diameter - 3in
    • JTR differential adapter, T56 yoke
    • 3.91 differential
    Engine
    • 2001 Corvette LS1 - purchased with a broken valve spring on cylinder #7
    • LS6 intake manifold
    • No A/C
    • Prior built list - by Lingenfelter Performance Engineering (30K miles ago)
    • GM LS1 block 3.900” bore
    • Water jacket plugs, oil galley & cam bearings
    • Manley forged aluminum pistons - coated
    • Manley moly file fit rings - 1.5mm, 1.5mm, 3.0mm
    • GM LS1 Crankshaft
    • Speed Pro heavy duty rod bearings
    • Speed Pro heavy duty main bearings
      Options:
    • Comp Cams camshaft - 224/224 .581/.581 114 (print on cam 3722R-3722R - R114)
    • Cloyes IRL
    • Poly Dyne bearing coating rod & main
    • Lingenfelter LS1 modified GM Oil pump deburred to improve flow
    Subject
    Flickr
    Engine
    Flickr
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    Looking forward to your build!
    Diving in at the shallow end!
    May 2009
    San Francisco
    99 E36 M3
    I have been working on compiling the parts list. I have ordered most and the parts are slowly trickling in.
    If anyone sees something major that I am missing, please let me know
    Parts Part number Vendor
    Valley cover (LS6) 12577927 Summit
    Valley cover PCV hose 12594779 Summit
    Valley cover grommet plug 12568011 Summit
    Tensioner and pulley ADO-12560344 Summit
    Valve springs TFS-2500286P Summit
    Valve springs removal tool TFS-90306 Summit
    Valve cover gaskets (2) 50504r Summit
    Push rods CCA-7955-1 Summit
    Coil packs ADO-D580 Summit
    coil brackets, ICT 551642 Summit
    Water pump ADO-252-846 Summit
    MAF 19330121 Summit
    Truck MAF harness 108100 Summit
    Head Gasket NAL-12498544 Summit
    Head bolts - ARP ARP-134-3609 Summit
    Thermostat (160*) LPE-L310015204 Summit
    Starter 829200 Summit
    Throttle cable TC-1000LS1U Summit
    Knock sensors 12589867 Summit
    Knock sensors wiring harness 917033 Summit
    ACDelco Pilot bearing ADO-CT1078 Summit
    Intake manifold gasket FEL-MS92438 Summit
    Fuel Filter/Reg - Corvette C5 SUM-230150 Summit
    Driveshaft 44.5 in long 16621 Coleman
    SPICER 2-3-6081X 2-3-6081X Summit
    JTR flange adapter JTR
    Clutch kit - LS7 LUK-04-216 Summit
    LS7 Flywheel LUK-LFW191 Summit
    Flywheel bolts ARP-330-2802 Summit
    PP bolts ARP-134-2201 Summit
    Oil dipstick and tube LOK-ED-5008 Summit
    Improved Racing baffle Imp Racing
    Oil pan Bolts ARP-134-6901 Summit
    Oil pump. Road racing spec MEL-10296 Summit
    Oil Pan gasket MAH-OS32241 Summit
    intake tube 4in in and out 9781 Summit
    Power Steering pump and pulley LS1FP Turnone
    Harmonic balancer bolt Amazon
    F body windage tray Ebay
    Front timing cover kit FelPro FEL-TCS45993 Summit
    Rear engine cover and main seal Ebay
    Remote bleeder kit HRE-8287 Summit
    Bleeder adapter AFC-7010-0007 Summit
    GM Performance Crankshaft bolt 12557840 Amazon
    Forgot to include initially:
    Camaro PCM with vats delete and start up tune that I forgot to mention in post #2
    F-Body accessories - alternator, tensioner pulley, Harmonic balancer - Auto Specialties Performance part # 948500. Slightly used
    F-Body oil pan with pick up tube
    Del a Where?
    LSx M3 & 2017 Touareg
    What valve springs broke looks like a single?
    If stock I'm not surprised they broke, I'm more so surprised whoever did all that work and did a cam on a stock valve spring, not to mention it looks like its on some baller Jesel rockers.
    Hopefully no further damage with the valve dropping.
    And for future I'd go with a BTR .660" Platinum Dual Spring kit over the trick flows.
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Don't see an ECU, front engine accessory drive, or headers (unless the CX Racing kit comes with it).
    I'm partial to Chuck's Super Tube headers and mounts. Uses OEM isolators (no vibrations) and custom size the headers - no mods/rubbing!
    Should be a fun project - with a beautiful soundtrack!
    May 2009
    San Francisco
    99 E36 M3
    Quote Originally Posted by Bsaint View Post
    A single valve spring broke. I am not sure if they are stock or not since this is the first LS engine I am ever looking at and not sure how to determine. Based on Summit's recommendation (my tuner also had stated that these are good for my setup) I went with - Trick Flow® Double Platinum .660 LS Dual Valve Spring and Retainer Kits TFS-2500286P. But thanks for recommendation. If you feel there is a concrete reason to switch, please let me know. Thanks for the input
    And yes, JESEL rockers -
    JESEL STN-SS 2030. Apparently they are good.
    May 2009
    San Francisco
    99 E36 M3
    Quote Originally Posted by Tim Mc View Post
    Thanks - fun and expensive project indeed
    Good notice on the missing parts - I did leave few out of the list:
    And yes, CX Racing kit that I have does include the headers. We will see how much pain will they be to install
    Del a Where?
    Quote Originally Posted by bmwvsevo View Post
    Just mind boggling to me someone put a cam in an LS with some expensive rockers on a single/stock valve spring.
    And I've just had great experience with BTRs never seen one fail where I've seen PRC's, Trick flows and other brands fail fairly often.
    May 2009
    San Francisco
    99 E36 M3
    Got it, well, now I know which springs to go with if anything happens in the future (knock on wood).
    Jul 2015
    Charlotte, NC
    1999 BMW M3 Coupe
    It is worth it to measure the pushrod length before installing to ensure you pick the right length rods. It is a pain to find out they are not right after everything is together.
    1999 E36 M3 Cosmo/Sand Beige LS1 swap
    2022 G42 230i Thundernight/Tacora
    Mar 2004
    USA
    96 328is 6.0L
    Don’t forget new Oil pick up tube O-ring and exhaust manifold MLS gaskets. Also since you are replacing valve springs, you might as well replace valve seals. I didn’t see these items on your list.
    May 2009
    San Francisco
    99 E36 M3
    Quote Originally Posted by bimerok View Post
    I will check if CX Racing did include exhaust manifold gaskets to make sure. Good point on valve seals. Rear engine cover gasket set does include the new Oil pickup tube o-ring. So I should be good there. Now a question is - do I need the bracket for oil pickup tube?
    2020-03-25_09-06-24 by Glen Babakhin, on Flickr
    Del a Where?
    Quote Originally Posted by smr87 View Post
    agree'd 7.400's "should" be correct based on his info, but who knows if the heads have been milled etc.
    May 2009
    San Francisco
    99 E36 M3
    Current push rods are - 7955 Competition cams 7.400 - .080
    Comp Cams/Summit/ and Jesel said that this is good size. So ill stick with the same ones
    May 2009
    San Francisco
    99 E36 M3
    I do get your points guys. Ill have to find out how to measure them since Ive never done it. Sounds like a good precaution.
    Mar 2004
    USA
    96 328is 6.0L
    I don’t see a reason for oil pickup tube bracket. Useless part.
    May 2009
    San Francisco
    99 E36 M3
    Got it, thanks
    May 2009
    San Francisco
    99 E36 M3
    So it begins. I started taking apart the engine. My original plan was to not take the heads off but do a leak down test and see if all holds up but I changed my mind and will be taking the heads off.
    For now, took the valley cover off, front timing cover, oil pump, and rear cover. And started to take the rockers, brackets, and push rods off. JESEL rocker brackets did require a thin wall 13mm socket that I didnt have so I had to order it through Amazon.
    Flickr
    Flickr
    Flickr
    Flickr
    Flickr
    Flickr
    Flickr
    Flickr
    What does everyone think of this damage on the rocker? Bearing seems to be ok. Do I 100% replace or possibly leave alone? Ive never dealt with the valvetrain myself therefore asking for an advice. I will also email JESEL with pics
    Flickr
    Flickr
    Del a Where?
    Flickr
    Flickr
    The nose rollers look untouched I don't see an issue running them,
    I'm more so interested to see how #7 piston & #7 cylinder wall looks.
    May 2009
    San Francisco
    99 E36 M3
    So i decided to take the heads off today. Bad news. Bent exhaust valve on cyl #7.
    Few questions now:
    Is it ok to leave the piston alone after the clean up? Info that I get is that its ok as long as there are no raised/sharp edges/chunks or cracks
    Anything else I need to do to the bottom end? I wanted to clean the carbon off and leave as is.
    I will take the heads to the machine shop. What is the total scope of work there? New valve and valve seal or is there more to it?
    Flickr
    Flickr
    Flickr
    May 2009
    San Francisco
    99 E36 M3
    Flickr
    Flickr
    Flickr
    Flickr
    Del a Where?
    Pretty much what I expected to see.
    It's hard for me to tell, but the sleeve doesn't look "that bad" The piston looks fine besides the carbon build up, I doubt the rod is bent. If it was my car I would clean it up and put it back together, but being as you are at this point and its not in the car yet I would send it out get it honed new rings etc. But for sure take it to a machine shop and get a better opinion for a few hundred bucks its worth having it refreshed have them look at the cam bearings etc as well.
    May 2009
    San Francisco
    99 E36 M3
    Understood. Thanks Steve. I might just take it to a machine shop to get inspected. That is whenever one opens up around here (all that shut down stuff).
    On another note, what do you clean the carbon off pistons with? I read about everything from WD40, to Mopar carbon removal, to acetone, etc
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    I'd think you would be extremely lucky if all it was is a bent valve.
    Rings and bearings for sure at this point...along with the inspection. Would hate to see the first time it hits 6500 rpm and the piston lets go and takes the entire engine out. (I have run an engine with a bent rod (forged)...no ill effects except lower compression on that cylinder - no I was not aware!).
    Mar 2004
    USA
    96 328is 6.0L
    Leave the carbon alone. More carbon = higher compression
  1. Alwaysbored786's E36 M3 LS1 Swap Build Thread
    By alwaysbored786 in forum Engine Conversions
    Last Post: 08-01-2018, 12:52 PM
  2. Attempting CA smog-legal E36 M3 LS1 swap
    By profplum in forum Engine Conversions
    Last Post: 06-04-2018, 02:31 PM
  3. 1997 E36 M3 with LS2/T56 swap - No Longer Available
    By jesh462 in forum 3 series & Z Series
    Last Post: 05-10-2016, 09:42 PM
  4. E36 M3 LS1 real world experience swap questions....
    By Steve91T in forum Engine Conversions
    Last Post: 10-06-2014, 08:51 AM
  5. E36 M3 LS1/T56 Conversion Harness - SOLD
    By EKnight in forum Car Audio & Electronics
    Last Post: 07-30-2014, 06:09 PM
