Results 1 to 25 of 54
Thread: Help! Air lines keep blowing off of air springs
    May 2014
    Fredericksburg, VA
    2000 528iT
    I'm getting close to my wit's end. The brass fittings with the plastic ring that provide air to the air springs keep popping off. They held on and held air over the weekend, but as soon as I put the front end of the car back on the ground to torque the control arm bushings, they popped. Each time the compressor kicks in and boosts the car back up to ride height, they pop off and drop the car.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Great conversation tonight by phone so Good luck and post your results! Snotty where were U?
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Oct 2016
    Atlanta
    2001 540iT
    I'm a thinking they weren't secure? Maybe they needed that second click
    Sent from my SM-G970U using Tapatalk
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Quote Originally Posted by StephenVA View Post
    Hi guys. just saw this. But i also just looked at my phone for the first time today after having dinner...., or ws that lunch? Maybe breakfast.
    Anyway, I've never worked on the E39's air ride system, I had a 528 wagon with SLS years ago, but i never had any problems with it. raftel did text me those same pics, and I said maybe some Vaseline might help seat the lines deeper? Aren't there locking clips involved? I don't know.
    Feb 2014
    Alexandria, VA
    https://www.bimmerforums.com/forum/s...r-info-for-SLS
    The black captive plastic pinch lock in the brass junction is
    NOT
    available separately. If you break it you need to buy a complete new reservoir and replace. PM or email me if this happens to you.
    Robert. inspect those captive pinch lock clips. Hopefully those knuckleheads didn't force the junctions off the airbag and screwed them up. See if you can get them to move with a pick. try not to distort the plastic as much as possible. Blast some compressed air at the junction housings, maybe some dirt is jammed in there keeping them from springing back to position properly.. They should be spring loaded, for some reason. they're not springing back into place, locking the junctions onto the airbags.
    Feb 2014
    Alexandria, VA
    Here's a link to an eBay seller based out of the UK, he's got 10 available.
    https://www.ebay.ie/itm/NEW-Pipe-Loc...4AAOSwgKRdn43f
    May 2014
    Fredericksburg, VA
    2000 528iT
    The clips are intact, and I've removed them and put them back on several times, they just don't stay locked in place. I've put a call in to Arnott for tech support, I'm waiting for a call back to see what they say.
    Feb 2014
    Alexandria, VA
    How is the channel in the airbag compared to the clip? The edges are square? Not rounded off?
    May 2014
    Fredericksburg, VA
    2000 528iT
    I spoke to Arnott, and they really didn't have anything except suggesting I turn the clips over, so I called FCP where I ordered the bags.
    They are shipping me some clips gratis today, and will also be shipping me BMW original bags - gratis. They seem to think that Arnott may have had a bad production run, so I'm getting original bags. They mentioned that bad runs have happened on occasion, but I really hope that's not the case. New bags should arrive Thursday.
    Incredible customer service, but I'm still not convinced user error is not at play here, so I will keep fussing with this until the new bags arrive.
    Feb 2014
    Alexandria, VA
    Wow! That is awesome! And I was actually thinking about that last night, about what if Arnott had a bad run, happens to the best of them. Awesome of FCP to ship out the higher dollar BMW units, and clips, which were supposed to be unobtainium.
    May 2014
    Fredericksburg, VA
    2000 528iT
    So FCP contacted me to say that they misspoke about the clips, and they are indeed only available as part of the reservoir. Oh well. I did finally get the passenger side to click in with the original BMW clips, but the driver side is still resisting my efforts. Now, I'm saying it's clipped in, but I have not pressurized the system again, so we'll see.
    I've attached some photos of the original BMW clip and the clips arnott provides with its bags. You can see the bevel in the arnott clip, but the BMW clip does not have one.
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Tell this to the other dude looking for cheap airbags. At least this one goes nowhere before failing.
    Quote Originally Posted by CPHES View Post
    Does the bmw clip fit on the Arnott bag?
    May 2014
    Fredericksburg, VA
    2000 528iT
    So far, the BMW clip is the only one that fits the Arnott bags at all when installed in the air fitting. I did get both the Arnott and BMW clips to lock on to the airbag if it was just the clip itself without the fitting, but I can't seem to push the fitting deeply enough into the airbag to get it to seat. It's as if the Arnott bags are machined just a touch too long or something.
    Feb 2014
    Alexandria, VA
    Stupid question, you are squeezing the clip with a pair of long nose pliers, correct? When you squeeze those two corner tabs, it opens up the clip, allowing you to push the air junction all the way in, then the clips lock it all in once they are in the connections channel. To remove the junction, you squeeze them again.
    Have you measured the two air ports to see if there is a difference?
    May 2014
    Fredericksburg, VA
    2000 528iT
    I thought that was only necessary when removing the lines. All the same, I went back and tried it that way. It made no difference. I'm thinking of just safety wiring the line onto the airbag. I figure, given a maximum pressure of 100psi, there could at most be about 20 lbs of force at play. Ugh.
    Nov 2016
    NY
    There is more than 20 lbs of pressure. I popped one connector off, and I thought the same thing. Not so. I don’t know the working pressure, but it keeps a 2 ton car level at speed.
    Sonoma Whine Country
    E12, E12, E36, E39
    I'm going to SWAG this out. Let say it's rated at 3,000 pounds before it bottoms out. How big is the contact point upper and lower, 25 square inches? Doing the math it suggests 60 PSI under max steady load. Spike on bumps? I dunno, 80? 100? Very ballpark figures.
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Nov 2016
    NY
    RTFM - read the.... you get the rest. Look at page 19 of the pdf linked - http://www.e38.org/selflevel.pdf
    The operating pressure is between 11.4 bar and 13.5 bar ( 1 bar = 14 psi ) - you do the math. Don’t assume that you know how this works. You will get hurt, or hurt others if you don’t do it right.
    Again - don’t buy cheap suspension parts. I’d put in a used OE bag over a new non OE bag.
    E12, E12, E36, E39
    I said it was a SWAG.
    98 328is
    02 525ita
    80 528i
    81 528ia
    Feb 2014
    Alexandria, VA
    Quote Originally Posted by Mike WW View Post
    Indeed you did, I did think it would've been a bit more though. I didn't think it would be at 160 to 189 pounds per square inch!
    Nov 2016
    Santa Cruz, CA
    2000 540i Touring
    I'm not sure I would call Arnott "cheap parts" because they at least try to be a solid US manufacturer of air suspension parts for many different makes and models and have always worked with customers on development and quality issues in my experience. Prior to owning our 540iT I had an Audi allroad. Audi allroads ate bags like drifters eat tires. Especially fun when they suddenly explode. I became quite familiar with Arnott and their lifetime warranty because they did have development and reliability issues with their allroad bags, but also worked with Audi forum members on product improvement. That said, they were doing continuous product development and offered top level customer service for exchanges. The last generation I used were decent. On the allroad the factory front bags sucked too, mostly because of the adjustable ride height on a bag that is also a front strut for steering the car. The good side is I could swap a front bag in around 30-45 minutes easily.
    So, when my 540iT needed bags I went with Arnott. The clip was a joke. I experienced the same would not fit issues as the OP has and could not make it work. Thankfully I did not break the OEM clips and they worked fine on the Arnott bags. So far so good, they are working well. Arnott is the only aftermarket bag I would go with and the factory bags seemed prohibitively expensive. Rear bags on the allroad can last over 200k miles (mine did) so I took the chance on Arnott based on my alllroad experiences. This was a couple of years now.
    I wonder if someone with cad and 3d printing talent could replicate the BMW clips???? Has anyone contacted Arnott to tell them their clips don't fit? (Guilty as charged, I should have when I changed my bags.) They do listen to customers and offer continuous development so there may be some hope there also.
    It should also be noted that at FCP right side BMW factory bags for non-sport suspensions are back-ordered so for those of with non-sport that need a bag right away Arnott may be the best choice. I am guessing if FCP are back-ordered other US suppliers probably are as well.
    May 2014
    Fredericksburg, VA
    2000 528iT
    It seems that the E53 X5 uses the same clip to secure the air springs. Luckily, my local pick and pull has several. Since suppliers of these clips are in Europe and will take weeks to get here, I think that is my next step.
    Nov 2016
    NY
    Arnott has mixed reviews. I think in the early days they were better. They do have a booming business in parts for GM and Ford Air suspension. you have to admit that the e39 Touring is a Niche market. The parts they sell as complete bolt in struts with bags seem to be ok, but there were issues with some of the products they made for earlier GMC Z55 Autoride trucks. ( Yes, I have one of those too ). From what I saw, I would not buy, but YMMV - and what is above does not speak well for them. I would not trust that for another 50k miles. I'd be worried about that connection blowing with every hard turn with a load in back. I took out the original bag in 2012 ( 202k ). The only issue I've had is the pump failing - also around the 200k mark. Yes, if you can get an OE clip to work on the Arnott bag, then try it out. Please take measurements from the Arnott bag. - Do you have OE bags to compare to now ( not sure what FCP did to make you whole ).
    May 2014
    Fredericksburg, VA
    2000 528iT
    No original bags to compare to, previous owner removed them and put coil overs in. I'll be scouring junkyards in coming days for OE clips to try. Not sure what FCP can do to help, BMW bags are in short supply so all they could do was offer another Arnott bag.
    Nov 2016
    Santa Cruz, CA
    2000 540i Touring
    Quote Originally Posted by raftel View Post
    That makes it difficult to use the OE clips. The X5 clips from the junkyard sound like a great idea (I'll have to remember to harvest some myself whenever life returns to normal enough to go to Pick N Pull).
    You might also try calling Arnott directly and tell them their clips didn't fit/lock and see what they say. I probably should have back when I replaced mine a couple years back if for no other reason than to let them know.
  1. Secondary air pump keeps blowing relays
    By nine9six in forum 1991 - 1999 (E36)
    Last Post: 08-19-2016, 08:08 PM
  2. Need help-headlight fuses keep blowing
    By 3series4ever in forum Lighting sponsored by BAVToys
    Last Post: 06-23-2011, 12:44 AM
  3. '82 528e air conditionar keeps blowing a fuse, why?
    By willsalaz in forum 1982 - 1988 (E28)
    Last Post: 03-26-2011, 04:51 PM
  4. 99 323i fuse no. 16 to air conditioner keep blowing.
    By davew0670 in forum 1991 - 1999 (E36)
    Last Post: 04-07-2010, 08:45 AM
  5. Air Conditioning keeps blowing fuse!
    By Cool 318ti in forum 1991 - 1999 (E36)
    Last Post: 09-29-2009, 12:16 PM
