BAVToys
Results 1 to 11 of 11
Thread: E36 w/Depo projectors - white halogen low / LED high?
    Feb 2020
    Orlando, FL
    Alpine white 1995 M3
    I'm not looking to spend a ton of money on a proper Xenon/HID conversion but would like better lighting than the standard US-spec lights on my 95 M3. Anyone done H1 halogens in a whiter color with H1 LEDs for the high beams? Recommended brands to match best? I guess I should do the white halogens in the fogs too ... recommendations?
    Dec 2009
    Detroit
    E36 Compact,Coupe,E30
    I've used Morimoto 2 Stroke 2.0 ($150) down to Hikari LEDs ($40) and have been satisfied with both. However I have used both in a low beam setup that has a projector. Time permitting (since we all can't go anywhere anyways) I can try the LED's in high beam but they may actually produce less light than the halogen being a reflector style. I had H1s Halogen and did not like the output. As long as you aim properly HIDs and LEDs have been fine. Plus our cars are pretty low anyways.
    As for fogs, I run yellow halogens since I can get foggy, however I've used LED and HID before as well. If you want to stick with halogen for ease, I use Nokya brand. Arctic or Cosmic white.
    S52 E36 Compact
    E36 325is Coronaproject
    08 Saab 9-3 in Oxford Green
    NY
    skateboard
    Quote Originally Posted by ZEKTI View Post
    What are the standard bulbs for depo's?
    ― George Orwell
    Dec 2009
    Detroit
    H1 halogens in low/high. 194 city bulb
    Sent from my iPhone using Tapatalk Pro
    S52 E36 Compact
    NY
    skateboard
    For some reason I thought it was H1 for low, and H7 for the high beams.
    ― George Orwell
    Dec 2009
    Detroit
    You are correct that some used H7 bulbs, possible other revisions or DJ Autos. Both these Depos and Euro Bosch use H1s in both.
    Also Morimoto came out with new LED headlight revision, it’s almost perfect for an led.
    S52 E36 Compact
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Dec 2009
    Detroit
    Quote Originally Posted by Mless5 View Post
    Morimoto makes industry standard aftermarket LEDS. Their newest product addresses some of the beam pattern issue and heats the housing. It's pretty neat. https://www.theretrofitsource.com/h1...H11?quantity=1
    S52 E36 Compact
    Peoria, AZ
    Interesting, thanks.
    Feb 2008
    Mt. Pleasant, SC, USA
    1997 E36 M3/4/5
    That's a link to fog lights. Do you know if the applications for zkw or depo projectors work well?
    Dec 2009
    Detroit
    Quote Originally Posted by marcva View Post
    What is a link to foglights?
    S52 E36 Compact
  1. e36 M3 Depo Projector Headlights
    By lbennyboobool in forum Exterior Lighting & Body Parts
    Last Post: 05-17-2016, 09:39 PM
  2. FS: E36 Sedan DEPO Projector Headlights & Amber Corners (Used)
    By phenom4 in forum Exterior Lighting & Body Parts
    Last Post: 12-29-2014, 10:38 PM
  3. Replies: 0
    Last Post: 02-13-2012, 10:49 PM
  4. E36 1999 E36 Alpine White Clean Low Miles
    By ashkan in forum 3 series & Z Series
    Last Post: 06-01-2011, 08:55 PM
  5. E36 New Depo Projector headlights $150
    By CMG in forum Exterior Lighting & Body Parts
    Last Post: 10-21-2007, 03:07 PM
