Results 1 to 8 of 8
Thread: Current Battery Recommendations (e36 M3)
    Jan 2005
    Medina, OH
    '86 e30, '96 M3
    Hi folks. Long time since I posted.
    After searching the forum, I wanted to ask what current batteries people recommend. I'm replacing the Interstate MTP-91 I installed in 2012. That was the top choice at the time but is no longer available. The MTP-91 was nice because of more CCA and less weight than the OEM battery.
    Thanks for any suggestions!
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Buy an AGM H6 battery. Brand is not so critical. Maybe Bosch?
    Jun 2010
    NY
    1997 328i
    Our cars charging system isn't designed for agm batteries. It's also a lot more expensive for no additional gains.
    Oct 2016
    Austria
    e36 323i, M3 3.2
    Jun 2005
    New England
    Quote Originally Posted by Eric93se View Post
    I have not had any problems using AGM batteries in my E36. They do cost more, but they last longer, are safer and are maintenance free. If you don’t drive much during parts of the year and do not put the a trickle charger in a regular battery, you will kill it faster than an AGM, which can better withstand discharging.
    Jan 2005
    Medina, OH
    '86 e30, '96 M3
    Thanks all. I appreciate the responses!
    Sep 2019
    Portland
    Too many to list
    I run OEM BMW AGM batteries in all my cars
    McKean township Pennsylva
    1999 M3 , 1999 328is
    I was looking for weight savings when I bought my battery, so I simply bought the smallest automotive battery available at Walmart. It was $50 and half of the weight of the stock battery. Works absolutely brilliantly with zero hesitation starting, even in the dead of winter. It is a daily driven car so the battery stays well charged.
    I previously had a very light weight lithium battery in the car, it didn't crank as strongly as the lead acid batteries do. Ultimately I had to ditch the lithium battery because the alternator voltage was just a bit to high for the cells and it damaged the lithium cells.
  1. Camber Plates - recommendation? E36 M3
    By BryDog in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-15-2009, 01:05 AM
  2. Changing battery in e36 M3
    By ihaveaE36m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-24-2008, 08:21 AM
  3. Race Seat Recommendation - E36 M3
    By BMW4LIFE in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-04-2007, 10:36 AM
  4. Battery Died - E36 M3
    By RE97M3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-02-2004, 03:34 PM
  5. What is the spec of the battery for E36 M3?
    By LEVOC///MPower in forum 1992 - 1999 M3 (E36)
    Last Post: 02-21-2003, 01:28 AM
