BMW of Bloomfield
Results 1 to 5 of 5
Thread: E39 2003 530i Sport Pkg 5sp manual - excellent condition
    May 2003
    Spring, TX
    ’02 M5, ‘03 540, ‘98 M3
    SOLD!!! E39 2003 530i Sport Pkg 5sp manual - excellent condition
    This 2003 BMW 530i Sport package with manual transmission has extensive records since new. In the last 18 months, it has undergone an extensive mechanical and cosmetic restoration. No detail was overlooked. This car needs absolutely nothing.
    When I purchased the car in September of 2018 with 126,000 miles, I had all the fluids changed and the sunroof repaired. The car has the following tasteful modifications:
    • Beyern mesh 18x9.5 wheels with Hankook Ventus 275/35 tires
    • AFE cold-air intake
    • Paint matched rear lip spoiler
    • Koni adjustable shocks with H&R sport springs
    • Slotted brake rotors with Akebono Euro Ceramic pads
    • Eibach front and rear sway bars and bushing
    • Strong-Strut strut tower brace
    • Schmeidmann sport headers and hi-flo cats
    • ZHP shift knob
    • E60 545i shifter refresh
    • Euro armrest with storage tray
    • Aftermarket cup holders
    • Front seats retrofitted with seat heaters/drivers seat retrofitted with comfort seat lumbar support
    • Avin Avant 4 head unit
    • BSW stage 1 speaker upgrade
    • Alpine custom mounted sub amp
    • Wheel studs/nuts
    • CDV delete
    • New custom wrapped steering wheel
    Here are the maintenance items addressed under my ownership (full service records available):
    • Fuel filter replaced
    • Replaced upper and lower front fender liners
    • New factory gray floor mats
    • Cabin air filters
    • Cooling system refresh (FCP Euro) – radiator, water pump, thermostat, hoses
    • Polished/ceramic coated headlights and replaced adjusters with Odo. Gears parts.
    • Replaced washer fluid hose
    • Replaced tool kit securing nut
    • Interior restoration including: new A/B/C pillars, new factory headliner, new sunroof switch panel, parcel shelf recovered, front seats re-dyed, driver’s seat new lower foam
    • Sunroof drains reamed and zip tied to drain tubes
    • Sunroof rain guard replaced
    • Front and rear suspension/steering overhaul (FCP Euro kit) – every suspension part (control arms, ball joints etc) including tie-rods and alignment
    • Replaced clutch (OEM), giubo, selector seal, rear main seal, pilot bearing, clutch pivot pin, CSB, shift carrier bushing, transmission mounts
    • All door panels removed/repaired where necessary, all vapor barriers resealed
    • Replaced various front and reads door gaskets
    • Shadowline trim removed and refinished
    • Installed new ZKW fog lights
    • Installed new Hella horns
    • Replaced CCV system
    • Replaced all vacuum hoses and vacuum caps on CCV and intake manifold
    • New gas cap
    • Rebuilt DISA with German Auto solutions kit
    • Replaced brake vacuum jet and hoses
    • Replaced all intake hoses/boots from MAF to DISA. Cleaned MAF and throttle body
    • Replaced valve cover gasket and spark plugs with NGK
    • Fixed all cables on both front seats due to seat “twist”
    • Oil pan gasket replaced
    • Motor mounts replaced
    • Replaced front and rear windshield gaskets
    • Replaced sunroof gasket
    • Replaced lower windshield trim
    • New windshield wipers
    • Replaced passenger rear seatbelt mechanism (2)
    • 100% of the dash pixels work
    Car currently has 147,750 miles. $7900 OBO
    SOLD!
    2002 M5 Sterling Gray (88k)
    Dinan mufflers and intake, ZHP shift knob, E60 shifter, Ground Control coilovers
    Restoration in progress!
    2021 M340i (25k)
    Sold!
    2003 540i MSport 6sp Tit Silver (193k)
    Dinan Exhaust, Autosolutions SSK, 88C Thermostat, Koni's, BlueBus, BavSound, DUDMD Stage 2, AFE CAI
    Sold!
    Aavi's 98 M3/4/5 Cosmos (137k)
    TMS Stage 3 with Shrick cams, Shorty headers and tune, M50, Stromung, 8.5 LTW's squared, PFC-Z, 3.38, Bosch H1's with city lights, CD43, BSW Stage 1, BMS SSK, TMS Underdrive Pulleys, Sunroof Eclipse, LeatherZ gauge pack
    BMW CCA# 308494
    Sep 2003
    whippany NJ
    1990 325is, 1990 325i
    Interested in seeing pictures, your link doesn't work, tried swapping in goog.gl but I get nothing.
    Sep 2003
    whippany NJ
    Figured it out after he sent me the link, replace the ****** with goo dot gl, not goog.gl
    May 2003
    Spring, TX
    2021 M340i (25k)
    Sold!
    Sold!
    BMW CCA# 308494
    Orlando, FL
    2001 530i
    I sincerely love everything about this car. Had an ‘01 in topaz blue, until 2014, and it pains me to this day that she’s gone. I MAY be interested, once I figure out how this Covid nonsense is going to affect me financially in the coming months.
  1. Replies: 2
    Last Post: 01-02-2014, 01:32 PM
  2. White rear shocks on 05/2003 530i sport pkg
    By John in VA in forum 1996 - 2003 (E39)
    Last Post: 10-06-2013, 01:55 PM
  3. NC e39 02 525i Sport Package 5sp manual
    By Staggerede34 in forum 5 series & 6 series
    Last Post: 02-23-2012, 06:09 PM
  4. E39 2003 530i - Sport Pkg - Low Miles!
    By samm3 in forum 5 series & 6 series
    Last Post: 02-08-2011, 12:57 AM
  5. E39 2003 530I sport package springs....
    By 33jacket in forum BMW Parts Wanted
    Last Post: 03-24-2007, 12:37 PM
