This 2003 BMW 530i Sport package with manual transmission has extensive records since new. In the last 18 months, it has undergone an extensive mechanical and cosmetic restoration. No detail was overlooked. This car needs absolutely nothing.
When I purchased the car in September of 2018 with 126,000 miles, I had all the fluids changed and the sunroof repaired. The car has the following tasteful modifications:
Beyern mesh 18x9.5 wheels with Hankook Ventus 275/35 tires
AFE cold-air intake
Paint matched rear lip spoiler
Koni adjustable shocks with H&R sport springs
Slotted brake rotors with Akebono Euro Ceramic pads
Eibach front and rear sway bars and bushing
Strong-Strut strut tower brace
Schmeidmann sport headers and hi-flo cats
ZHP shift knob
E60 545i shifter refresh
Euro armrest with storage tray
Aftermarket cup holders
Front seats retrofitted with seat heaters/drivers seat retrofitted with comfort seat lumbar support
Avin Avant 4 head unit
BSW stage 1 speaker upgrade
Alpine custom mounted sub amp
Wheel studs/nuts
CDV delete
New custom wrapped steering wheel
Here are the maintenance items addressed under my ownership (full service records available):
Fuel filter replaced
Replaced upper and lower front fender liners
New factory gray floor mats
Cabin air filters
Cooling system refresh (FCP Euro) radiator, water pump, thermostat, hoses
Polished/ceramic coated headlights and replaced adjusters with Odo. Gears parts.
Replaced washer fluid hose
Replaced tool kit securing nut
Interior restoration including: new A/B/C pillars, new factory headliner, new sunroof switch panel, parcel shelf recovered, front seats re-dyed, drivers seat new lower foam
Sunroof drains reamed and zip tied to drain tubes
Sunroof rain guard replaced
Front and rear suspension/steering overhaul (FCP Euro kit) every suspension part (control arms, ball joints etc) including tie-rods and alignment
Replaced clutch (OEM), giubo, selector seal, rear main seal, pilot bearing, clutch pivot pin, CSB, shift carrier bushing, transmission mounts
All door panels removed/repaired where necessary, all vapor barriers resealed
Replaced various front and reads door gaskets
Shadowline trim removed and refinished
Installed new ZKW fog lights
Installed new Hella horns
Replaced CCV system
Replaced all vacuum hoses and vacuum caps on CCV and intake manifold
New gas cap
Rebuilt DISA with German Auto solutions kit
Replaced brake vacuum jet and hoses
Replaced all intake hoses/boots from MAF to DISA. Cleaned MAF and throttle body
Replaced valve cover gasket and spark plugs with NGK
Fixed all cables on both front seats due to seat twist
Oil pan gasket replaced
Motor mounts replaced
Replaced front and rear windshield gaskets
Replaced sunroof gasket
Replaced lower windshield trim
New windshield wipers
Replaced passenger rear seatbelt mechanism (2)
100% of the dash pixels work
Car currently has 147,750 miles. $7900 OBO
SOLD!
2002 M5 Sterling Gray (88k)
Dinan mufflers and intake, ZHP shift knob, E60 shifter, Ground Control coilovers
Restoration in progress!
2021 M340i (25k)
Sold!
2003 540i MSport 6sp Tit Silver (193k)
Dinan Exhaust, Autosolutions SSK, 88C Thermostat, Koni's, BlueBus, BavSound, DUDMD Stage 2, AFE CAI
Sold!
Aavi's 98 M3/4/5 Cosmos (137k)
TMS Stage 3 with Shrick cams, Shorty headers and tune, M50, Stromung, 8.5 LTW's squared, PFC-Z, 3.38, Bosch H1's with city lights, CD43, BSW Stage 1, BMS SSK, TMS Underdrive Pulleys, Sunroof Eclipse, LeatherZ gauge pack
BMW CCA# 308494
Interested in seeing pictures, your link doesn't work, tried swapping in goog.gl but I get nothing.
Figured it out after he sent me the link, replace the ****** with goo dot gl, not goog.gl
2021 M340i (25k)
Sold!
Sold!
BMW CCA# 308494
I sincerely love everything about this car. Had an 01 in topaz blue, until 2014, and it pains me to this day that shes gone. I MAY be interested, once I figure out how this Covid nonsense is going to affect me financially in the coming months.
