I could do the M version but I am not sure how should I improve the stock item? Maybe bigger opening to airfilter direction?
What is centre dash pod? Do you mean like additional gaugepod? I am not sure if that wouldn't clash with the design lanquage of the interior.
You can also say directly if you think price is wrong. I would like to move these units so that they benefit the users. If there would be multiple buyers at same shipping I would happily give some discount as it saves my time doing and shipping packages.
Z3 & E36 RamAir systems, send private message for more information.
The M Cars already have a snorkel that sucks air out of the duct that kinda runs to the brakes, but it isn't stout enough to give a ram air effect. The airbox has a tube that goes down to the area already. The change would be to make a scoop like you have already done, but to fit the M bumper, then connect it to the stock airbox with a better tube, or DUAL tubs for MOAR POWER.
Honestly, this isn't going to do all that much for performance, but its cool so we will still buy them because we are clinically insane.
The ACS fog light kit mounts small hella DE fog lights into the duct towards the outside of the car, but its pretty involved to install.
Same for the hamann foglight kit I have, but it mounts them towards the inside, you have to cut a lot of the bumper away and blend in the fiberglass components for either kit.
If you could make a duct that attaches to the stock M bumper that also has small led fogs. The DEs were super small for 20 years ago, maybe something smaller now? I just want to use my stock dash switches, even if fogs aren't necessary.
White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
I like Coupes.
I’m interested please
Hi, are you selling the STL?
Just wanted to say thanks, I used the ram air intake along with some 3in ducting routed to the factory airbox and it worked fantastically. I had to drive about an hour and a half to an autocross event so the heat soak would've been terrible, but with your intake my engine had a steady flow of cold air all day long
Are you still selling these?
I'm interested in the files for the air funnel w/ mesh along with the piece that attaches underneath the airbox (what do we do about the hose, is that included or do we need to pick up the hose separately?
Zed's dead baby. Zed's dead.
You have to get the hose yourself, I got mine from advance auto in their performance section. It's just some basic 3inch ducting and silicone connectors, however you'll want to get two 3 inch clamps to secure the hose to the funnel. If you're planning on hooking up the ducting to the stock air box, just remove the plastic ducting under the driver side headlight (just a few 8mm nuts and plastic push clips) and run the ducting straight into the air box. The inlet on the airbox is slightly larger than 3 inches, so I just wrapped some duct tape around the duct and inlet and it worked fine. Hope this helps!
I made this tiktok about the process too https://www.tiktok.com/t/ZTRuY2p3M/
Yes of course. Send me private message or contact me in social media, IG, FB jne... What do you need?
BTW... The meshed part is finally now done for very easy 3D printing at home.
You will print the big parts face down with supports, and 2 of each of the green parts that are very small and easy to attach and locate now with simple snap fit. If you print in ABS or ASA you can simply slightly wipe contact surfaces with acetone and the parts will melt together as one. Or you can ofcouse use almost anykind of glue with good results. Super Glue, Gorilla Glue, 2 part epoxy etc. We do this meshed model like that, so that we can save 10 hours of very hard to remove supports printing per part, and instead just print very clean parts with minimal supports. Always want to use 100% infill in these parts.
Printed and attached pair of new meshed variant will look like this:
So far of about 100 pairs sold, which of about half in USA, only one has broken when my friend crashed his Z3 on the track on the wall. I will support him with replacement unit for only price of cheapest shipping.
PM sent
Hi, are these still up for grabs (the file to get it 3D printed?) thanks so much
You might need to have 10 posts or so to be able to send PM, my email is posted here earlier too. I wont post it now again, because I get _a metric shit-ton_ of more spam mail after posting it onto any forum.
Since last posts are from 6 months ago, letting you know that products are available and they have been even more further redesigned for better print quality etc.
Shipping prices have once again been doubled since I last time wrote, so I will price case by case and by shipping type.
Hi !!
First off, thanks a lot for getting the 3D print design done for our Z3s!!
My Z3 didnt have a fog light; it has a plastic cover where the fog light assembly would be.
which means I dont have the circled part shown below
So from the options you have listed, is this the block off plate? if not do you have a STL file that will have this plate as well?
I am interested in the above setup (is the cost $35 ???)
-- Air Funnel with Mesh +
-- the plate +
-- the engine induction ramair outlet
Please do let me know and I can transfer the money through Paypal immediately!
Thanks and have a great day!
I don't remember paying that much for them, but it's possible I did. I still have them unmounted, keep waiting for the right car to install them on...
Hello, sorry for extremely long delay, I dont want to force my product too often on the forums but occasionally come to see if someone needs them.
I cant see the image where circled part would be? But I am quessing that you are meaning the stick end? Unfortunately and very rare case that bmwfans.info does not show the part numbers for those. I tried to investigate this, yours is first one ever I come across with no foglights, can you post the picture again so that I could see it?
PM sent. Excellent work designing and refining these!
Question: Where did you get the flexible ducting used to connect the 2 parts from intake to engine bay?
Basically any lightweight airhose will do. If it has smooth inside, that is great. This is what I recommend always: https://www.do88performance.com/en/a...quot-76mm.html but anything similar from ebay or amazon will work ofcourse.
I answered the PM:s.
Here are few installed in Z3 Coupes in Finland, Norway, France and Netherlands.
I think car should have come like this from factory. They look totally OEM but more sporty. Ofcourse function is that matters really. Yes, I am biased.
