Hoping there's a quick fix! Drivers door locks and unlocks with the key but the other three doors don't. Have checked the fuse. There are 2 clicks which come from the left side of the speedo when you unlock the drivers door.
Any thoughts? I have checked other threads and I'll look at the module under the dash. Its a Euro 745i but think this system is standard?
All thoughts gratefully received.
Thank you!
The others could be unplugged. My trunk was on the 10/84...no idea why.
Try the trunk to see if it activates the central locking. Passenger side will also unlock and lock all on a working system.
I make E23 parts.
10/1984 745i
11/1984 745i
11/1984 735i (10:1-265/6)
There may be micro switches on the drivers side latch that get worn then don't send the signal out, but I may be thinking of the locking set up on the e32
