Results 1 to 5 of 5
Thread: Coding low beam error E46
    Mar 2020
    Wakefield
    E46 330cd
    Just a quick one. And hopefully an easy one for somebody.
    A while back I fitted a crap hid kit that apparently needed a wiring harness. Because of the wiring harness, both headlights run off one relay that was wired to one headlight. So I coded the warning light out.
    Now I’ve purchased a good hid kit, removed the harness and tried to code back in the warning light on the dash. Only now I can’t find what I think to be the correct option - FEHLER_ABBLENDLICHT ?
    Firstly, am I looking for the correct option for low beam error for the dash light.
    If so, why the hell can’t I find it in any of the modules. I’ve paid most attention to AKMB and ALSZ
    It’s also on a 2006 E46
    Much appreciated
    Jul 2004
    Houston, TX
    36 Cylinders
    Have you tried just to default code it back to stock?
    SG_Codieren with a blank/untouched .MAN file
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mar 2020
    Wakefield
    E46 330cd
    Actually no I haven’t? Do you mean literally just load a blank .MAN file through ncs and that will roll it back to stock?
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, the .man file is a manipulation file for the stock coding job.
    The stock coding is calculated out of the VO/FA code every time.
    So when you do an sg_codieren job without manipulating, it goes back to stock.
    -Abel
    Mar 2020
    Wakefield
    E46 330cd
    Thank you. Really appreciate it
  1. E36 HID W/low beam error code
    By chuck328IS in forum Lighting sponsored by BAVToys
    Last Post: 01-27-2013, 01:24 AM
  2. Replies: 7
    Last Post: 03-19-2011, 06:49 PM
  3. Low beam error even with DDM error code eliminator
    By E34play in forum 1988 - 1996 (E34)
    Last Post: 09-13-2010, 09:05 PM
  4. Low Beam error
    By 92E34 in forum 1988 - 1996 (E34)
    Last Post: 08-29-2006, 07:28 AM
  5. Replies: 6
    Last Post: 05-27-2004, 10:11 PM
