Hey,
So I have what I believe to me a blown channel on my head units OEM built in amp.
No power at all to front left speakers.
Am I able to do a fix on this at all by sourcing parts from eBay and the like or will it be a replacement CCC?
I'm running the pro nav so quite costly to replace, hoping to avoid that if I could perhaps source parts and/or a faulty unit in order to fix mine up.
2006 E60 530d
Thanks.
It’s likely that the amp, located in the left side of the boot is the cause of the problem. Pop the boot lid and remove the vertical panel to see if you have any water infiltration. While you’re there remove and reinstall the main connector. Here’s the realoem page: https://www.realoem.com/bmw/enUS/sho...diagId=65_1314
