Results 1 to 5 of 5
Thread: S50B30 valves - use stock S50B32?
    Kitchener, Ontario, Canad
    2 x Euro-spec E36 M3s
    So, I知 going to need to redo my head at some point in the future, and I値l have it lightly ported and polished at that time. My question is regarding the valves. If it痴 an easy (ish) swap, will I be able to use the stock size valves from the later S50B32? I know that the stems are a mm smaller, and the head size is a bit bigger - both good things.
    I just haven't tracked down a 3.2 lower head for a reasonable price yet.
    Thanks,
    Cheap. Fast. Reliable. Choose 2.
    Avus Blue '94 M3 Euro-spec
    Arctic Silver '94 M3 Euro-spec - sold
    Estoril Blue '97 M3 Euro-spec
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    i'd wait for a complete b32 head the ports are better its not just the valves
    BMW E30 325is M20B33 in the making....... ITB's, roller rockers and stroked to the hilt
    Ok, thanks. Are the throttle bodies worth tracking down, too, or not too much gain from them?
    The Netherlands
    German E36 328i & M3 cab
    Hard to say. They are 1mm larger in diameter. 6x .5mm larger radius.
    But then I would also use the shorter B32 intake trumpets.
    98 BMW M3 3.2 SMG Cabrio Alpinwei゚ III auf Schwarz Deutschland-ausfhrung
    IG:
    Quote Originally Posted by digger View Post
    But just how much better? Only the intake valves are bigger, and the stems are smaller.
    How much better can the ports be? The valves are the same lengths, so that means that the seats are in the same locations. It’s not like they changed the radii significantly.
  1. Where to buy new/used stock headlights?
    By IwantMCoupe in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-09-2003, 05:04 PM
  2. Replies: 3
    Last Post: 04-09-2003, 01:18 PM
  3. Replies: 2
    Last Post: 12-24-2002, 04:29 AM
  4. WTB: Used stock springs and shocks for a 95 325is
    By M3corey in forum BMW Parts Wanted
    Last Post: 11-03-2002, 12:06 AM
  5. For those that are using stock non-HK stereo
    By JT-KGY in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-22-2001, 01:20 AM
