Results 1 to 3 of 3
Thread: 2003 525iT Headlight issue
    May 2010
    Midwest
    E36M3/4 E39T&E61 E39M5
    My driver's side Angel eyes are inop... Bulb has been swapped and still nothing. Any ideas of what could be wrong?
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Dude, bulb changing 101, install new bulb, it doesn’t work? Check to see if the harness has voltage? If so, than........ the bulb you got is a dud. Bulb works??? Then..... maybe the bulb you got is not the right one and not making contact in the bulb housing? No voltage at the harness? Then maybe check the fuse? Other side working? Maybe the LCM is acting up?
    May 2010
    Midwest
    Determined the LCM is acting up... Can they be reset or should I buy a donor, and get it coded to my car... Is there a mail in repair service that could fix the current one? Need to get figured out before my new lights go in... I will never buy $15 Amazon Halo Led's ever again, Pretty sure that's what caused my issue. Kinda lost because electrical problems are my kryptonite..
    Please Advise!
  1. Headlight issue on 2003 E46
    By OddJungle in forum Lighting sponsored by BAVToys
    Last Post: 02-09-2016, 10:48 PM
  2. Headlight issue on 2003 E46
    By OddJungle in forum 1999 - 2006 (E46)
    Last Post: 11-09-2015, 10:25 PM
  3. 2003 E46 headlight issue
    Last Post: 11-09-2015, 08:44 PM
  4. 2003 M3 headlight issue 60,307k
    By RocknRolla69 in forum 2001 - 2006 M3 (E46)
    Last Post: 10-30-2008, 09:24 PM
  5. Headlight issues...grr
    By Angela318 in forum 1983 - 1991 (E30)
    Last Post: 06-08-2003, 07:59 PM
