Hello. I'm looking for a newer version of the NAV map dvd. For the E53/E65 ibus MK4 dvd drives. Olny have the original 2006 version. The dealer doesn't have them anymore, can't order them. What's my best option? Part number for referenceis 65 90 2 365 699. thank you
The last DVD North American map for the MK4 was 2015...that's the best you're going to get. You may be able to find some of those DVDs on eBay or amazon.com. Good luck.
EDIT: here's an example...I'm not endorsing this vendor...I only found it doing a quick ebay search based on the info you gave: https://www.ebay.com/itm/BMW-Update-....c100047.m2108
I would also suggest running that part nbr through one of the online part database sites like www.realoem.com so that you can see the superseded part nbrs. That may be helpful in narrowing the search for compatible DVDs. If you do this, you'll see that there are multiple part nbrs that are compatible.
My last DVD nav update for my 2006 e53 X5 was the 2014 maps...prior to that I upgraded to the 2012 maps...I purchased both off the internet from either eBay or amazon.com for less than $25 both times:
