Results 1 to 7 of 7
Thread: 328d Transfer Case swap problems
    Mar 2020
    Hanover, Pennsylvania
    2014 328d
    Hey y'all. My brother's car is 2014 328d xdrive. We installed a new transfer case and used the old transfer case motor/controller. It's still throwing codes with both the old controller and the new one. We have a Zurich code reader/programmer to diagnose the engine codes. We entered the code but thinking the code we entered was wrong. It was very difficult you read the stamped codes, it was like crappy Braille. We're getting the following two codes on the Zurich reader. Does anyone have any idea what's wrong? The first code is saying the transfer case is different. We installed ATC35L, Zurich code is showing ATCx50
    Sent from my moto x4 using Tapatalk
    Canada
    750 F01, 850i, LR3 HSE
    Did you use a "brand new" transfer case or a used unit?
    After replacing the transfer case you will have to carry out an adaptation procedure. In the course of this procedure you must enter the MPT calibration number stamped on the transfer case.
    You need the last 4 or 5 digits from the MPT number.
    Mark.
    Jul 2004
    Houston, TX
    36 Cylinders
    I think you need better diagnostic devices to begin with. Harbor Freight tool probably doesn't program the calibration value nor initialize the transfer case correctly.
    Also regarding the transfer case output flange (very likely why you've replaced it):
    https://f30.bimmerpost.com/forums/sh....php?t=1579087
    You can prevent it.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mar 2020
    2014 328d
    Quote Originally Posted by mandd View Post
    Mark.
    Thank you Mark. We installed a used unit. Might pull it out again to dinner 5 check the numbers we entered
    Mar 2020
    2014 328d
    You can prevent it.
    Thank you. Was worried about that. I know every tool doesn't have the ability for every car, unfortunately. I will check the video. Think that's why he had to do this in the first place messing up the output shaft. Thank you!
    Jul 2004
    Houston, TX
    36 Cylinders
    Do you have any shops or good BMW traveling diagnosticians around you?
    If you have a Windows laptop and an ENET cable (cheap), I can possibly help you remotely, via remote desktop.
    -Abel
    Mar 2020
    2014 328d
    Thank you. He ended up going to the dealer. He's pissed about buying the Zurich though! I appreciate the offer though sincerely!!!
  1. Recalibration / coding after Transfer Case swap
    By RockOn in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-05-2019, 01:39 PM
  2. How prevalent are 328d transfer case issues?
    By TNorth in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 10-09-2018, 07:35 PM
  3. E53 transfer case common problems
    By glenncai in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-10-2014, 05:55 PM
  4. 2001 x5 3.0L - transfer case problem?
    By opdelrio1 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 07-07-2011, 02:11 AM
  5. Replies: 2
    Last Post: 08-31-2010, 11:37 AM
