Results 1 to 3 of 3
Thread: Car won't start after valve cover (VCG) job
    Oct 2007
    Treasure coast
    E84 N20B20, E30 M42B18
    Hello all,
    So just finished replacing my Valve cover and gaskets on my N20 engine with 82k miles. Tedious job but pretty straightforward. I have done all VCGs on all my bimmers E30, E46, E92, and never had a problem.
    However, the car won't start. It cranks but it won't start. Battery was disconnected before the job and fully charged with my battery tender overnight after the job. I double checked all connections, bolt torques, etc. and all seems to be ok. I read the codes with bimmerlink and the only one I get is:
    Code A10A
    EWS4_Timing_Chall_Resp_Fehler
    Symptom: No signal".
    Any suggestions? -appreciate any input.
    Jan 2016
    Ca
    2001 525it
    Some thing happened during work check it all again
    Oct 2007
    Treasure coast
    Thanks for your reply. It is fixed, the key point is that when you reinstall the fuel pump, the exhaust camshaft has to be at bottom dead center. Also the fuel rail needed to be bled.
  1. HELP! Car won't start after valve cover gasket replacment
    By AmericanJambo in forum 1996 - 2003 (E39)
    Last Post: 10-11-2019, 02:46 PM
  2. Car not starting after valve cover gasket
    By b325xi in forum 1999 - 2006 (E46)
    Last Post: 10-08-2018, 08:33 AM
  3. Car won't start after valve gasket job
    By bigds01 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-25-2017, 12:14 PM
  4. Car puts out smoke when starting after valve cover gasket replacement. Is it normal?
    By utennvols2010 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-16-2013, 09:16 AM
  5. Car won't start after valve cover gasket replaced
    By e39hamann in forum 1996 - 2003 (E39)
    Last Post: 05-21-2009, 01:24 AM
