Results 1 to 3 of 3
Thread: Oil Leak
    Mar 2020
    Los Angeles
    2014 BMW 528i
    Oil Leak
    I drive a 2014 BMW 528i with 202,000 miles. I have been dealing with several oil leaks that have been costly the last few months. Back in December 2019, my oil cooler had a major oil leak that resulted in my alternator needing to be replaced. Then this past Friday Feb 28, I replaced my valve cover that was leaking a lot of oil as well.
    The shop techs did check for any other leaks but none were located. Now this morning I noticed another small leak in my driveway. Would there by chance be any residual oil from cable cover fix that was done? Should I again worry that I need another repair?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Hard to say. You’re in a warm climate so you could carefully clean around the areas that received oil from the (hopefully) corrected oil leaks. There are a lot of electrical components and electronix under the hood, so if you decide to clean up the engine you want use something that’s not going to run.
    Feb 2020
    Canada
    2011 535i xdrive GT
    Has the gasket seal been replaced at your oil pan?
  1. Amsoil 0/30W = oil leaks?
    By Uber328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-22-2002, 06:16 PM
  2. What is this (oil leak?)?
    By M3Nut in forum 1992 - 1999 M3 (E36)
    Last Post: 05-13-2002, 11:40 PM
  3. Help! Questions about oil leak and CPO coverage.
    By ToddGT in forum 1991 - 1999 (E36)
    Last Post: 09-17-2001, 12:01 PM
  4. I found my Oil Leak! (sorry kinda long)
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2001, 03:50 PM
  5. oil leak......lost 1/2 quart in 300 miles
    Last Post: 08-08-2001, 01:10 PM
