Results 1 to 6 of 6
Thread: Secondary ignition image question (with pic)
    Jan 2017
    The Netherlands
    850i
    Hi, I used an old scope to show the secondary ignition pattern of both banks of my M70 engine.
    The image for bank 1-6 seems to be perfectly OK (perhaps mixture too lean?).
    The image for bank 7-12 shows an anomaly during charging of the coil: a flat line.
    Anyone a suggestion of what could be going wrong at coil 7-12?
    I will continue measurements, also of primary currents at the coils.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I would check the primary and secondary coil resistance - the flat bit before ignition should show current increasing to the point of saturation - and I can't see that. It could also be a measurement error depending on how you have coupled the 'scope probe.
    My BMW Repair YouTube Channel
    Aug 2019
    Tujunga, CA 91042
    850CI740Lsezd750L95sezd
    So trace 1-6 has field building in coil. In 7-12 beautiful digital waveform before spike. I wish all my digital ckts looked that good. Objective of digital ckts -> nil capacitance, nil reluctance. Look for corroded electrical terminals that are limiting current keeping coil from building field.
    Jan 2017
    The Netherlands
    850i
    Quote Originally Posted by CD05001CIA View Post
    Thanks. Trace 1-6 looks like the reference image in the workshop manual, trace 7-12 does not. In fact trace 7-12 looks like a primary instead of secondary image, but it is really secondary like trace 1-6. The inflow current may be limited, but the field does actually build up in the 7-12 coil.
    Thanks. Both coils measure 0.5 ohm primary resistance, which seems to be OK. Still the 7-12 current inflow may be limited because of a wiring problem; I will try to measure currents on another scope.
    BTW I used an old Bosch MOT-206 scope, and just relocated the pick-up clamp from coil output 1-6 to 7-12. So both graphs are directly comparable.
    Jan 2017
    The Netherlands
    850i
    The current inflows of both coils follow a straight line, see image. No horizontal part due to current limiting. I guess that's OK (although most examples show a flat current limiting part).
    What I noticed is that the secondary traces taken between the coils and distributors look fine (see pic). However, when measured at the individual plugs, many traces are worse causing a lot of misfiring.
    Distributor/rotor problem?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That means you have distributor problems - dodgy rotor arm, dirty contacts etc
  1. 2nd gear and ignition sticks... questions
    By warpalien in forum 1999 - 2006 (E46)
    Last Post: 07-07-2005, 05:45 PM
  2. Tinting question and pic request
    By GJM325i in forum 1999 - 2006 (E46)
    Last Post: 12-08-2003, 12:07 PM
  3. headlight question and pic
    By MILLA RACING in forum 2001 - 2006 M3 (E46)
    Last Post: 11-03-2003, 03:01 PM
  4. Ignition coil question
    By Blazin95Red325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-05-2003, 02:28 AM
  5. AC SchnitzerType II wheel question and pic request
    By m3j0n in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-18-2003, 01:11 PM
