Results 1 to 7 of 7
Thread: Front brake problems
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    I have an 04 M3. It was purchased late 2018. Drove fine.
    I prepared it for SCCA Solo STU class competition. I had been using Ferodo DS2500 pads on E36 328i and M3 with great results. But, not so much with the 46 M3. In street driving, no issues. But in competition using DS2500s again, the brakes were heavy and both my co-driver and I were losing boost and could not invoke ABS on dry pavement. There are no issues with the booster as it holds vacuum for weeks when just sitting.
    Today, I pulled the calipers to resurface the rotors to bed the pads again. SURPRISE !!!!!!!!!!!!! After a full season literally hundreds of runs in local events, a couple of Pro Solos, Divisionals, a Tour, and Solo Nats, the front pads had only a millimeter or two of wear, while the rears were about 25% worn. And THAT seems BACKWARDS.
    The system has DOT4 fluid and has been bled a couple of times during the year. This leaves me with the conclusion of a master cylinder and/or proportioning valve issues. It would be nice to know how one could determine where the problem may be. Thoughts?
    Sep 2018
    Maryland
    2001 M3 Coupe Track Car
    maybe someone swapped the front and rear brake circuits on the MC?
    Jul 2010
    KC, Mo
    Quote Originally Posted by eacmen View Post
    VERY doubtful. But, I will look.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Check the drag and temp on the rotors after taking the car for a drive. You maybe looking at a dragging caliper(s). The rears will tend to wear less on these cars I have noticed, so being at 25% doesn't surprise me too much.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jul 2010
    KC, Mo
    dworthy, the front pads are NOTE WEARING, even after a full season of autocross with two driver's.
    Turns out the master cylinder was bad. Found one on eBay out of an 06 M3 for less than $100 shipped WITH the vacuum booster. Swapped the master and all is good.
    dworthy's Avatar
    Nov 2010
    Ah NOT Wearing, sorry I missed that as I thought the pads had only 1-2mm left.
    So yeah I am surprised that you didn't lock-up the rear wheels on every turn if the blockage was that great in the MC.
    Darin
    Current:
    Past:
    M-Flight Member
    Jul 2010
    KC, Mo
    The front brakes were functional, but when used hard, the pedal felt like there was loss of boost, and actually the pedal was being pressed so hard that available was used up between solo elements.
    I may attempt to dissect the MC.
  1. right front brake problem
    By theeges in forum 1988 - 1996 (E34)
    Last Post: 03-09-2007, 08:50 AM
  2. Front Brake Problem??
    By arsinal4496 in forum 1991 - 1999 (E36)
    Last Post: 10-09-2006, 01:44 AM
  3. Front Brakes...Problem!!! please help :)
    By MP525i in forum 1992 - 1999 M3 (E36)
    Last Post: 02-17-2005, 09:16 AM
  4. Major Brake and Front Suspension Problem
    Last Post: 03-26-2004, 11:44 AM
  5. Replies: 12
    Last Post: 07-11-2003, 08:08 AM
