RM European Auto Parts
Results 1 to 6 of 6
Thread: G48 Green or Blue?
    Jan 2020
    El Dorado Hills, CA
    94 BMW 325i Convertible
    Question G48 Green or Blue?
    As simple of a question as it sounds, this one has me stumped.
    I'm currently rebuilding my E36 M50 motor out of my '94 325i. I picked up two gallons of coolant to refill the system with. (I already had half a gallon at home)
    Here's where it gets weird: All three of these coolant containers are Zerex G48 50/50 coolant. All three containers appear to be the same. And yet, one of these three containers has green coolant instead of blue. I can't find any difference on the bottles between the green and blue.
    If both of these containers are supposedly the exact same stuff then why is one green and the other blue? What's the difference? I know you typically can't mix coolant but can you mix these if they're the same stuff? I have more blue than green, but when I started refilling the system I used the green first. (I didn't even realize they were different colors until my coolant came out of the bottle green, to my surprise.) If I want to use blue instead do I need to do a full flush to clean out the half gallon of green I've put in so far?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Contact Zerex via the company’s customer service phone number. Are the Zerex part numbers on the containers the same?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    G48 is fine. Color makes no difference. I’d buy blue just so anyone who works on the car knows it’s different from nurnsl green. Zerex GO5 is also fine to use in BMWs.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    We have G48 at our shop, for BMW's and MB's. It is blue, every time. Even the label is blue. If I found green coolant in a G48 bottle, I would return it.
    Chris Powell
    BMWCCA 274412
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    yeah - very strange. is the UPC/barcode/part number the same on all the bottles here?
    Sep 2001
    So. Cal
    05 M3, 01 Z3M, Jeep ZJ
    Quote Originally Posted by shadowpuck View Post
    ran into this today. i used g48 in 2018, and it was blue. i open a new container to put into my e46 m3 today and it was bright neon green. I called valvoline and they said they changed the die.
    But why would they do that?
    Current:
    2001 S54 M-Coupe
    2011 Mini Cooper Countryman S
    94 Grand Cherokee Laredo 4.0L/242 TC (Daily)
    Past:
    95 325i Convertible/Boston Green
    01 330Ci Convertible/Steel Grey/Stick
    05 Infiniti G35 Premium/Tech
  1. Green and Blue dash light switch?
    By elocsitruc in forum 1991 - 1999 (E36)
    Last Post: 07-14-2013, 04:12 PM
  2. coolant swap - green to blue
    By bmw2nv in forum 1991 - 1999 (E36)
    Last Post: 12-21-2012, 01:10 PM
  3. Going from Green to Blue...
    By m3 bavaria in forum 1988 - 1996 (E34)
    Last Post: 05-17-2012, 09:41 PM
  4. Coolant Flush - Green to Blue
    By kickservebt in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-16-2007, 11:51 AM
  5. Fuel Pump 318ti; Green or Blue?
    By watchmyradical in forum 1991 - 1999 (E36)
    Last Post: 11-08-2006, 08:06 AM
