Swapping a M20 into the ‘83 320i and I need to confirm that the top fuel line (flared with a nut to screw to the line to the fuel distributor) is the supply line and the bottom is the return. Overthinking I am sure.
Replies appreciated!
Thanks, Eric
Yes, #1 with the nut and slip ring is the fuel supply to the fuel distributor. The other #10 fuel line with the hose clamp is the return to the fuel tank.
https://www.realoem.com/bmw/enUS/sho...diagId=13_0113
Tbd
Thank you Epmedia!
