Manual trans, the plug has been leaking for a while, tried rtv on the outside as a stop-gap, that failed, finally I took the plug out and wrapped it in Teflon tape as I had seen suggested, reinstalled/refilled, and it’s still leaking, haven’t even driven the car since the ‘fix’.
Is a new plug likely to stop the leaking or could there be something else going on?
Hopefully not a cracked case ,these are tapered plugs and if overtightened will crack the aluminum cases
Sent from my SM-G960U using Tapatalk
Angus
88 E30M3 X2 (1 summer/1 racetrack)
89 325IX (winter)
92 R100GS/PD
ah ok thanks I'll inspect it closely.
