89 750il
Hey Guys
I'm in Limp mode. It is running on Cylinders 1-6 Passenger side of the V-12 left hand drive
What I've noticed is if I push on the white relay in the below pictures that has the red wire attached to the green/yellow wire with the fuse in it the car stops
My question is do all the relay boxes out there have this red wire with the fuse in it.?
I;m suspecting a PO added this to bypass something ..what were they trying to bypass?
The below the white relay connectors have a white relay in each I believe they are the DME relays.
The black connectors hold the fuel pump relays.
looks not original with the red wire with inline fuse. Here you see original http://bmwe32.masscom.net/sean750/fu...t/Fuelpump.htm
the location of the fuel pump relays can differ from model to model when it comes to the relay box near the right strut tower.
