Driving home all of a sudden I hear clank clank clank. Almost like I'm dragging something under the engine. I was around 1000 feet from home. Smelled antifreeze. Made it home. Dripping antifreeze when I got home. I'm suspecting it was a blown water pump. Any opinions or advice?
Sorry to hear. Can you open your hood and take a look and some pictures?
Kelvin
I’d look at the lower rad hose connector to see if it popped. Check your fan and make sure it didn’t explode into the radiator. Belts still intact ?
Check the fan for missing blades.
/.randy
I think it may be water pump related because while limping home the batter light flickered for a second. I assume that is from the alternator drive belt. Have a puddle of antifreeze under the car. I just ran to the store and bought kitty litter for that. It was making a really weird clacking. Almost like I was dragging tin cans from the front of the car. I will check the hoses and fan now. Then I will just let it sleep till tomorrow.
Ironic that yesterday I bought a new garage floor after months of waiting. Now until I get this car fixed I can not put down the new floor if its delivered.
I have never let anyone work on my cars in about 30 years or so but this repair may be time.
Update the fan blades are hitting the fan shroud when I go to turn them. That may have been the weird clacking I heard. The angle of the part that goes to the fan blade is partly at an angle instead of straight. Top hoses seem intact. Didnt get on the ground to check the lower hose yet.
Update #2 when I squeeze the upper hose I hear a slurp up top. I assume that is either the thermostat housing or the water pump. I do have more fluid come out when I squeeze the upper hose even though the hose seems intact.
It sounds like a cooling system refresh is in your near future. Is it all original?
You need to locate the leak first but it sounds like either the pulley failed sending the fan into the rad or the pump bearing/impeller failed. I’d plan on replacing the radiator/reservoir if it’s original. The plastic end tanks and fittings fracture easily with age. Of course there’s all the other hoses ,idlers thermostat and housing. Gotta love these old cars.
Happened to me a few months ago...The water pump went, fan blades broke and serpentine belts wear shredded. Luckily for me I was close to home. Ended up replacing the fan, water pump, belts and while I was at it, I replaced the hoses, thermostat and fan clutch.
I used poor wording. I will definitely repair it. My car is in very good condition. I just meant that I don't want to turn a $1000 repair in to a $3000 repair by going crazy with $1000 radiators, etc.
Did you do it all yourself or have a shop do it? How much did it cost you?
Just curious Kram. How many miles on your car?
You can’t have everything. Where would you put it?
So did you actually find out what the problem or are we all just pissing in the wind
Radiators are definitely not 1000 bucks. Check out FCP euro. Lifetime guarantee on all parts. I would seriously consider doing a full cooling system refresh if you are over 150K. Time consuming, but pretty easy.
Looks like the Nissens radiator is 150 bucks. We use this brand in our endurance car (M54 vs S52, so not apples to apples) and it keeps everything plenty cool.
Around 91,000 and in very good condition.
I have to be more careful how I word things. I was not saying that normal radiators are $1000. I was saying I do not want to go overboard with crazy high performance parts. I know they make some aftermarket radiators that are around $900.
Think its the water pump but until I pull it I will not be able to tell if its just the waterpump.
I know there is a aftermarket heavyduty high performance waterpump. Does anyone have a link for a waterpump suggestion?
I have the M54 Engine..Replaced all the parts myself. Everything could be accessed from the top. The thermostat and water pump is easy to get to and replace. The Water pump I went with was HEPU. The pump has a metal impeller vs. the OEM Plastic one I had. Hoses,belts,thermostat,water pump, fan, fan clutch and coolant just shy of $400.
Oh, boy, I see another cooling system bleed discussion in the near future
Tony
"You can't sign away negligence."
